Wow over two weeks since I posted last.
Did the above test so no power drain
Cleaned all my connections and heat shrinked them tight. I did find that one of my connections from the wired George mod was loose, as well the black wire from my starter button was loose, and the blue turn signal wire was loose. So three wire loose may have caused a short. These are all fixed now.
New ignition is installed and timing is set
No riding today since its raining ug. but once it stops the beast will run again I hope
