big block streetability,in all seriousness
  • PLUMMEN
  • PLUMMEN's Avatar
Re: big block streetability,in all seriousness
07 Nov 2009 17:29
#332021
jordan wrote:
PLUMMEN wrote:
8:1?????
yep,taking a little of block and a smidge off the head should put it in the ball park.nice flat lids for flame travel B)
  • PLUMMEN
  • PLUMMEN's Avatar
07 Nov 2009 17:32
#332022
jordan wrote:
hahahahahhahahahaha, you old guys and you're bickering. Well wouldnt a high compression 1075 be just as unstreetable? I kinda figured i would build a motor with all the potential right away, but just stay toned down. if i want more power, i just need to go to higher compression pistons and bigger cams. I would rather have it this way than to make the same power out of a small motor at max potential. I just wanna know if i can still take my dragbike to the car show, or for a little cruise once and a while. I have other bikes to ride, so this one will be just for fun
:laugh:
  • jordan
  • jordan's Avatar Topic Author
07 Nov 2009 17:32
#332023
i was really considering building a blow through turbo system, or nitrous bike. Thats why i was thinkin i could build a nice lower compression motor, then spray the hell out of it on the dragstrip
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • PLUMMEN
  • PLUMMEN's Avatar
07 Nov 2009 17:37
#332026
racer54 wrote:
Sure...a big-block on the street is feasible. Lots of them out there. I plan on doing it myself. I'm in the same spot as you...deciding on what compression ratio to use. Just remember that to get the most out of it, it will come down to the combination of ALL the parts. What cams you planning on running? They will help determine what compression ratio you might want to run. You can run high compression with any cam but the bigger cams need the higher ratio to get the full benefit from the high lifts. Smaller cams don't need the high ratio so you can get by with the lower compression ratio and be more streetable. You need to decide just how radical you want or how much power you want out of it. I know of guys running 13:1 with .460/.485 cams on the street but I'm sure it's temperamental but is sure would get gone in a hurry! Also, once you get past .435 lift, the head has to be set up different then with the smaller cams and that will dictate which cams you can run. You can't switch back and forth. Lets hear from you know-it-alls out there on your opinions on this!
big bore and a light crank(sounds like a porno! :S :blink: :huh: :laugh: )mid size cams .380-.410 range with a decent head.this thing will make so much power so quick youll be seeking counseling! :woohoo:
  • PLUMMEN
  • PLUMMEN's Avatar
07 Nov 2009 17:39
#332028
exactly,youre learning oh wise one!
  • racer54
  • racer54's Avatar
07 Nov 2009 17:39
#332029
Don't know how much truth there is to this but was told a few years ago that 11:1 was a good ratio for nitrous. Have no idea why that particular ratio but this guy was a nitrous runner so figured he knew what he was talking about. BUT...just recently read on another site to not worry about compression ratio...build the motor and spray! Go figure. Both of your ideas have their weak and strong points though.
  • PLUMMEN
  • PLUMMEN's Avatar
07 Nov 2009 17:42
#332032
im thinking pump gas and stump pulling torque and midrange ,which is exactly what a streetbike needs B)
  • jordan
07 Nov 2009 17:45
#332033
then feed it juice goin down the dragstrip :evil:
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • jordan
07 Nov 2009 17:49
#332034
how bout 8:1 j model pistons? bring compression up around 10:1 for streetability, then pump it full of nitrous on the strip
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • PLUMMEN
  • PLUMMEN's Avatar
07 Nov 2009 17:53
#332036
are you using a j head?
  • jordan
07 Nov 2009 17:55
#332038
not any more, sold it and will be using an old style head
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
  • arai59
  • arai59's Avatar
07 Nov 2009 19:37
#332061
Speaking of J heads.........Jordan....Plummen is busy working out the details on your future big block..........hold on a sec........he's almost done.
