- Thank you received: 10
Joy of Joys!!! Piston ring in my oil pan.
- timebomb33
18 Sep 2009 11:02 #322393
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic Joy of Joys!!! Piston ring in my oil pan.
i did a 24 hour ice race years ago with a xs650 twin flat tracker in the last hour it started to use a bit of oil so after we got it back home we tore it down and when i pulled the barrel of both sets of rings fell into the bottom of the engine so how could it even have run is beyond me.
- PLUMMEN
- Thank you received: 104
18 Sep 2009 18:04 #322429
by PLUMMEN
Replied by PLUMMEN on topic Joy of Joys!!! Piston ring in my oil pan.
years ago i had my old faithfull 61 chevy k30 4x4 dumptruck with a respectable running 400 chevy smallblock that would puff just a little when youd first start it,so i decided to do a good set of heads with a valve job high rise intake,headers and cam to wake it up a little .the damn thing always ran around 60psi of oil pressure so i figured bottem end was solid and was gonna leave it alone. well in typical gearhead fashion i ended up tearing into the bottem end anyway and come to find out half the rings in it were broke! from there i decided one of hye tech performances 415 smallblock kits would be perfect with a .510 lift cam a good set of heads would be perfect ! :woohoo: thats also where the name of my plumbing co HYE TECH UTILITIES inc came from.anyway i figured every 1 ton 4x4 dumptruck should have a 450hp motor :laugh:
- roy-b-boy-b
- Thank you received: 103
19 Sep 2009 04:37 #322472
by roy-b-boy-b
Replied by roy-b-boy-b on topic Joy of Joys!!! Piston ring in my oil pan.
I had a friend i use to work for and he had a Dodge Dually we called "Goat".
He had a "67" GTX that he raced. He built a new motor for the car and we installed the old engine in the "Goat". Was a lot of FUN!!!!
:woohoo:
:woohoo:
- txturbo
- Ex-Kawasaki Mechanic 1981-1985
19 Sep 2009 05:11 - 19 Sep 2009 05:26 #322474
by txturbo
1984 ZX750 E1 GPz Turbo
1984 ZX1100 A2 GPz
1984 ZX900
1996 KZ1000P Police bike
1970 Honda CT 70H 4sp manual
1965 Honda Dream 305
2003 Honda Shadow 1100
1971 Suzuki MT50 Trailhopper
1969 Camaro SS
1966 Impala
1966 Impala SS 427/4spd
Replied by txturbo on topic Joy of Joys!!! Piston ring in my oil pan.
I've seen a lot of rings broken upon installation. Thats my guess. Each piston has 4 rings...so it will run with one of them missing completely.It will just use a little oil or lose a little compression on that cylinder.Since the middle ring is the one missing,it would still run fine but was probably a little low on compression on that cylinder. If you thought it ran good with missing rings....you will really like it with all the parts included! :woohoo:
Those chunks of metal in the pan don't look good. Is that iron or aluminum? They stick to a magnet? My guess would be aluminum. If you broke those rings while installing the cylinder those ring pieces probably gouged out some aluminum from the case as they went past the crank and into the pan. Clean the pan out,hone the cylinders and install a fresh set of rings and you should be ok.Just make sure you don't break any rings this time.
1984 ZX1100 A2 GPz
1984 ZX900
1969 Camaro SS
1966 Impala
Last edit: 19 Sep 2009 05:26 by txturbo.
- Old Man Rock
- Thank you received: 225
19 Sep 2009 06:35 #322480
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Joy of Joys!!! Piston ring in my oil pan.
Well we can sit and discuss theories all day long for weeks to come but one thing for sure.....
You thought your KZ ran well before, pulled strong, power etc.... Wait till you get her all fixed up and dialed in.... When you twist that throttle.... hold on! :evil:
Shit brother, your grin will be so wide it will split your helmet... :woohoo:
Brings a tear of joy to ones eyes when another KZ is put back to life don't it.... :laugh:
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
