Joy of Joys!!! Piston ring in my oil pan.
12 Sep 2009 16:11 #321123 by Sweet Back
Joy of Joys!!! Piston ring in my oil pan. was created by Sweet Back
Bike wouldn't start. Didn't have dough for registration, had other bikes, parked it. Finally was able to start it and it sounded "hollow". Don't ask. Thought maybe it was the oil pump. Pulled the pan and found half a piston ring and ground metal in the pan. I replaced those rings about 2 years ago. I'll be pulling it apart soon, but I have 2 questions in the mean time.
Is it possible for a ring to slide down into the pan, without the piston being f'd?
What could make a ring break in only 2 years?
Thanks all, as always.
1996 KZ1000P
  • kano
  • Not Another Bloody Limey!
12 Sep 2009 16:15 #321127 by kano
you have two hopes:
bob hope!
and no hope!
however there is the possibility that the bits have been in there from a previous incident.
do a compression test,
leak down test,
check for low numbers before tare down.
12 Sep 2009 16:16 #321128 by Sweet Back
Replied by Sweet Back on topic Joy of Joys!!! Piston ring in my oil pan.
Oh, and is it a bad idea to put used pistons in there if indeed the piston is jacked?
1996 KZ1000P
  • kano
12 Sep 2009 16:24 #321130 by kano
don't be surprised if its more than the piston bro,
i chipped a valve and it trashed the valve, piston, rings and the sleeve too.
you have had a whole piston ring fall apart in the bore and some how it squeezed past the piston, got past the crank and ended up in the sump.
not good news!
expect the worst!
you won't be disappointed that way!
12 Sep 2009 16:52 #321140 by Old Man Rock
Replied by Old Man Rock on topic Joy of Joys!!! Piston ring in my oil pan.
Screw the compression/leak down test....
OPEN HER UP!!!!
There's only one way you'll ever have a piece of mind on this.... You mentioned you installed these rings 2 years ago, so did you have pieces in there then... probably not...
So yourself a big favor, open her up, slide off the cylinder and confirm otherwise who knows what extent of damage is there.... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
12 Sep 2009 17:20 #321144 by keith1
Replied by keith1 on topic Joy of Joys!!! Piston ring in my oil pan.
OPEN HER UP!!!!
i second that...you are not gonna ride it anyways right?
in pcs knowing the prob or sitting there complete not knowing are the same.....good luck
  • kano
12 Sep 2009 17:23 #321146 by kano
i hate taring down motors :laugh:
that why i said do some tests first :blush:
i'd buy a new motor before i pulled a motor apart :blink:
and stick the busted one in the corner under a pile of rags :dry:
12 Sep 2009 17:35 #321150 by Old Man Rock
:laugh: :laugh: :laugh: :laugh:
Kano, You lazy bastard....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
12 Sep 2009 18:02 #321157 by Mark Wing
Replied by Mark Wing on topic Joy of Joys!!! Piston ring in my oil pan.
Oh David that doesn't sound good, I third the thought you should at least pull the head and take a look inside. Sorry to rear this.
Mark
Yorba Linda Cal.
12 Sep 2009 21:24 #321230 by TerryK
Replied by TerryK on topic Joy of Joys!!! Piston ring in my oil pan.
Do a leakdown or compression test. Instant results, with no tear down.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
12 Sep 2009 23:00 #321243 by bountyhunter
Replied by bountyhunter on topic Joy of Joys!!! Piston ring in my oil pan.
+1 There is only a couple of thousandths clearance between the cylinder wall and the piston. Even if the ring breaks into pieces in the piston groove, it could not get out to fall unless something really messed up the piston or bore to increase the gap.
Sorry.
12 Sep 2009 23:04 #321244 by bountyhunter
I would never do it because it's so much work to rebuild it that I don't want to risk it. I can't tell what bike this is. New 750 twin piston/ring sets are dirt cheap, 900/1000 are pricey.
