- Thank you received: 225
Joy of Joys!!! Piston ring in my oil pan.
- Old Man Rock
You're only lucky SOB.... KZ Gods are with you...:woohoo:
Well, one thing to measure is the play in the rods and with a feeler gauge, piston to cylinder wall clearances...
Maybe this was large enough for the ring piece to slip by which would explain a few things....
I don't have a PS manual but I do have the KZ900/1000/1100 manual procedures may be close to the same if you need the procedures... Let me know...
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
Ok, so I got in there today, and well, nothing definitive, at least to me. I posted all the pics I took in case someone sees something I don't. I'll inspect the cylinder more tomorrow. I found the other half of the ring still on the piston. The piston looks good and doesn't seem to have any more travel than the others. The only difference I notice is it has less carbon build up, whatever. There's a pic of the metal in the pan. I'm going to inspect that more because I have a suspicion it may not be from the ring. I'll be looking this thing over with a fine tooth comb tomorrow. Just thought I'd post the info now.
www.fileden.com/files/2009/5/29/2459697/DSCF3009%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3010%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3011%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3012%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3013%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3014%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3015%5B1%5D
www.fileden.com/files/2009/5/29/2459697/DSCF3016%5B1%5D
that second pic is downright funky.....you see bits like that stuck to plug if its pinging real bad...not a herd of em stuck to top of piston.....detonation will kill ringlands as well piston tops, but they dont look bad ...just half a ring gone....what does the head look like?...got a pic?.....how that half a ring skated out without major damage is a mystery for the ages!!!..good luck...keep us posted......keith
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- PLUMMEN
- Thank you received: 104
- PLUMMEN
Sweet Back wrote:
Ok, so I got in there today, and well, nothing definitive, at least to me. I posted all the pics I took in case someone sees something I don't. I'll inspect the cylinder more tomorrow. I found the other half of the ring still on the piston. The piston looks good and doesn't seem to have any more travel than the others. The only difference I notice is it has less carbon build up, whatever. There's a pic of the metal in the pan. I'm going to inspect that more because I have a suspicion it may not be from the ring. I'll be looking this thing over with a fine tooth comb tomorrow. Just thought I'd post the info now. if the pictures dont fit,you must ed-it! :laugh: (jonny cocharan!)damn those pictures are huge! :laugh:
- Sweet Back
- PLUMMEN
- nads.com
- Thank you received: 20
- MDawnz1
- Thank you received: 27
1974 Z1a, still 903
- bountyhunter
- Thank you received: 337
The ONLY way that ring got into the bottom end is if YOU BROKE THE RING LAST TIME YOU PUT THE CYL. ON .
Been there done that, but I saw it when I did it as a piece went flying by....
- Sweet Back
- PLUMMEN
