Joy of Joys!!! Piston ring in my oil pan.
- Sweet Back
Is it possible for a ring to slide down into the pan, without the piston being f'd?
What could make a ring break in only 2 years?
Thanks all, as always.
- kano
- Not Another Bloody Limey!
bob hope!
and no hope!
however there is the possibility that the bits have been in there from a previous incident.
do a compression test,
leak down test,
check for low numbers before tare down.
- Sweet Back
- kano
i chipped a valve and it trashed the valve, piston, rings and the sleeve too.
you have had a whole piston ring fall apart in the bore and some how it squeezed past the piston, got past the crank and ended up in the sump.
not good news!
expect the worst!
you won't be disappointed that way!
- Old Man Rock
- Thank you received: 225
OPEN HER UP!!!!
There's only one way you'll ever have a piece of mind on this.... You mentioned you installed these rings 2 years ago, so did you have pieces in there then... probably not...
So yourself a big favor, open her up, slide off the cylinder and confirm otherwise who knows what extent of damage is there....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- keith1
Screw the compression/leak down test....
OPEN HER UP!!!!
i second that...you are not gonna ride it anyways right?
in pcs knowing the prob or sitting there complete not knowing are the same.....good luck
- kano
that why i said do some tests first :blush:
i'd buy a new motor before i pulled a motor apart :blink:
and stick the busted one in the corner under a pile of rags :dry:
- Old Man Rock
Kano, You lazy bastard....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Mark Wing
Mark
Yorba Linda Cal.
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- bountyhunter
- Thank you received: 337
+1 There is only a couple of thousandths clearance between the cylinder wall and the piston. Even if the ring breaks into pieces in the piston groove, it could not get out to fall unless something really messed up the piston or bore to increase the gap.don't be surprised if its more than the piston bro,
Sorry.
- bountyhunter
I would never do it because it's so much work to rebuild it that I don't want to risk it. I can't tell what bike this is. New 750 twin piston/ring sets are dirt cheap, 900/1000 are pricey.Oh, and is it a bad idea to put used pistons in there if indeed the piston is jacked?
