- Thank you received: 22
My z1 motor wont turn over
- Mark Wing
check omrs cam writeup
Once you start to install the cams you DO NOT turn the motor over. I deal with 650's but I know you don't turn over the motor.
Mark
Yorba Linda Cal.
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- oldkaws4ever
- Have no regrets...... You only live once.
- Thank you received: 12
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- roy-b-boy-b
- Thank you received: 103
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
- Thank you received: 3
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- Old Man Rock
- Thank you received: 225
Also assuming your using stock OEM cams, not adjustable CAM sprockets... Either case, this portion is the same other wise follow the Dumb%%*&%* tutorial...
Set your timing mark on cylinder 1/4 on "T" and leave for the moment.
Then insert camshafts as in the following diagram...
NOTE: The 28th count is one pin up from the mark then 28 over!!!!
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
- Thank you received: 104
- riverroad
- 1980 1000LTD B4
- Thank you received: 7
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
