My z1 motor wont turn over
  • oldkaws4ever
  • Topic Author
  • Have no regrets...... You only live once.
03 Apr 2009 18:21 #278191 by oldkaws4ever
My z1 motor wont turn over was created by oldkaws4ever
Ok, i went to kick over my motor in the z1 after i got it in the frame, i wanted to get the cams timed in. And low and behold it was stuck in place. So i took off the head, and poured some automatic transmission fluid down each of the cylinders in hopes of freeing it up. How long should i wait for the trans fluid to do its magic? Im bummed out because im so close to getting her read to run. Any ideas guy's? Thank's, Jim
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
03 Apr 2009 18:33 #278193 by PLUMMEN
Replied by PLUMMEN on topic My z1 motor wont turn over
usually i just dump some gas/oil down the plug holes and let it sit overnight and try again.can you turn it over with kick starter? if its stuck dont try turnining it over with the bolt under points cover,use kick starter.did you drain the oil out when you pulled the motor,what have you done to the motor?;)
  • oldkaws4ever
  • Topic Author
03 Apr 2009 18:41 - 03 Apr 2009 18:44 #278196 by oldkaws4ever
Replied by oldkaws4ever on topic My z1 motor wont turn over
I tried with the kicker yesterday and it was a no go. Ya i drained the oil in the motor because i had to replace the oil pan gasket and i polished all the engine covers, i had the head off to replace it with one from a 1979 kz 1000. Other than that nothing else has been done. I know not to turn the bolt under the points cover because i read about it sheering off.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
Last edit: 03 Apr 2009 18:44 by oldkaws4ever.
03 Apr 2009 18:46 #278199 by PLUMMEN
try kicking it over slowly while the head is still off make sure to pull slack out of timing chain 1st so it dont ball up on the crank sprocket,youll need to buy a new base gasket and head gasket anyway.let us know if it moves that way ;)
03 Apr 2009 18:50 #278201 by roy-b-boy-b
Replied by roy-b-boy-b on topic My z1 motor wont turn over
I agree with plummen. I have had the timing chain get beside the sprocket and not turn over.
Take your time. Roy
  • oldkaws4ever
  • Topic Author
03 Apr 2009 18:51 #278202 by oldkaws4ever
The cylinders are still on the bike so no need for a base gasket, but i do have a new 2 peice head gasket and rubber o-ring for the middle. I will let ya know if i get her free. Im going to try it tommorow and see if i can get it free.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • oldkaws4ever
  • Topic Author
03 Apr 2009 18:57 #278205 by oldkaws4ever
i was thinking that also roy, but when i went to pull the cylinders i coudnt get them to budge. Is there any trick's to it?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
03 Apr 2009 19:44 #278218 by roy-b-boy-b
I wouldn't pull the jugs. If anything i would pull the oil pan. A good time to clean out 30+ years of crud. Roy
  • trianglelaguna
03 Apr 2009 19:51 - 03 Apr 2009 19:53 #278221 by trianglelaguna
Replied by trianglelaguna on topic My z1 motor wont turn over
if the jugs wont pull up then the rings have seized on....i know....you...this....i'm reading what the guys are saying and agree too...i think the jugs should slide a bit up without any real tugging...when i just got my rings in last week the cyl block had tight but feelable slide to it...good luck...if you need the hone stone brush to rehone...i have a new one i'll lend ya...no worries ...it will get solved....go easy you be fine..take your time dont snap nothing...i'm talking to me too...i just got my cometic 72 mm h-gskt yesterday and sunday is the build continues day...good luck
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
Last edit: 03 Apr 2009 19:53 by trianglelaguna.
  • oldkaws4ever
  • Topic Author
03 Apr 2009 19:59 #278222 by oldkaws4ever
Ya thats why i didnt pull the jugs because after i put the head on before the teardown the compression came up to 117 in all the cylinders so the rings are good. I think the time the motor sat idle the rings stuck to the cylinders, hence the reason i put some trans fluid down the cylinders.....im hoping that will do the trick. When i originally pulled the pan there was no sludge what so ever on the pan it was really clean for being a 35 year old motor, i did clean the pump real good though.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
  • trianglelaguna
03 Apr 2009 20:02 #278224 by trianglelaguna
how long since the rings moved a bit
1976 KZ900
2003 ZX12R
2007 FZ1000
  • oldkaws4ever
  • Topic Author
03 Apr 2009 20:14 #278232 by oldkaws4ever
Let's see, late october early november, but it has sat im my heated garage the whole time and hasent been outside or anything like that.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
