- Thank you received: 12
My z1 motor wont turn over
- oldkaws4ever
- Have no regrets...... You only live once.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
- Thank you received: 104
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- PLUMMEN
- roy-b-boy-b
- Thank you received: 103
Take your time. Roy
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- roy-b-boy-b
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- oldkaws4ever
I wouldn't pull the jugs. If anything i would pull the oil pan. A good time to clean out 30+ years of crud. Roy
Ya thats why i didnt pull the jugs because after i put the head on before the teardown the compression came up to 117 in all the cylinders so the rings are good. I think the time the motor sat idle the rings stuck to the cylinders, hence the reason i put some trans fluid down the cylinders.....im hoping that will do the trick. When i originally pulled the pan there was no sludge what so ever on the pan it was really clean for being a 35 year old motor, i did clean the pump real good though.
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- trianglelaguna
1976 KZ900
2003 ZX12R
2007 FZ1000
- oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
