- Thank you received: 43
Engine Just Blew??
- 79MKII
- Love Them Kaws!
The Kaw List:
- mark1122
- Keep twisting it
- Thank you received: 109
i hate leaks. the dry block my be a future project. there are a couple hear somewhere. tuxedotito has 1.
PM me your email addy and i'll send u a file .
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- larrycavan
- Visitor
My valve cover gasket should be here today or tomorrow. Now I have to decide exactly what to do to try and stop the madness. I was talking about the silicone all over the gasket thing just last night. It's just weird that I never had to do anything like that before.
I also have a new can of gasgacinch and that's supposed to be pretty good stuff. Here's the really strange part though - I helped my friend rebuild his top end ('80 LTD 1000 with chronic base gasket seepage)and we used gasgacinch for the first time on everything. It worked super great on the base gasket, head gasket, and all other gaskets EXCEPT the valve cover gasket. He had a blow out right above his front left cam end plug. We just replaced it with another gasket and it's slipping out in the same area. It's not leaking yet but it appears to be only a matter of time. The bolts are tight, the surfaces are clean, the gasgacinch was applied and it still looks like it's going to slip out. There were no upper end components changed that would cause a valve cover seating issue and it doesn't leak anywhere else. I had never seen this problem before in over 25 years of owning KZ's and now I can't rebuild one without the valve cover gasket blowing out!! :S
Sounds like you're probably putting too much torque on the valve cover bolts. No matter how many you work on, there's always something that shows up on one that never did on 50 previous motors....
OEM gaskets are the best way to go but so expensive. Veserah are also pretty good.
If it continues to be a situation, you might try using a spring loaded prick punch on the surface. Put some little sharp edge dimples in for the gasket to bite to.
Another thing that will surely cure that is put case sealer on the surface or gasket. Just put it on one surface though and you might get lucky with reusing the gasket at valve adjustment time.
I have a gasket too that takes biscuits. Leaves a nice, slightly scuffed finish on surfaces. Allows the gasket to get hold of the metal.
- rssuby2001
Ken McCormick
- rssuby2001
Ken McCormick
- Old Man Rock
- Thank you received: 225
I also add a little dab of Permatex gasket maker over the top of the cam end caps (mine are aluminum caps)....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- 79MKII
- Love Them Kaws!
That's what I used this last time - even that stuff didn't save me when the bolts came loose.
As far as overtightening the bolts - the gasket doesn't squeeze out, it gets blown out later while riding, after the bolts loosen up. If anything, maybe I didn't go tight enough? Whatever the reason is, I'll be checking the bolt torque more frequently and using loc-tite this time.
Thanks for the tips.
The Kaw List:
- Old Man Rock
I also use this on the SS bolts to aluminum threading, wonder if this is making a difference as well....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
Very good idea on the cam cap bolts - those steel bolts like to pull out aluminum threads for sure.
I hope to get it together tonight or tomorrow night and we'll see how it goes this time...
The Kaw List:
- Old Man Rock
Actually on all my SS bolts to aluminum throughout the engine, side covers, pan cover bolts, engine/head etc...
Now on my original engine break in period, sure some bolts loosened up especially the head bolts but that was/is expected....
Maybe due to additional compressions in your build....
I like the lock tight idea but for one thing... We get into the valve cover quite a few times a year for valve adjustments and such and that crap seems to accumulate over time....
Maybe a flat and lock washer on your bolts.... I know, I know but if it holds what the hell....
If you come up with a solution let us know for if happening to you, it's going to happen to others as well....
One thing for sure, fix her for your KZ is just so damn beautiful and oil all over just wont work... I mean damn it, the motor is so clean I'm like, WTF does he even ride this thing....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- 79MKII
- Love Them Kaws!
Thanks for the compliments on the bike. I've only got 180 miles since the rebuild, so I haven't ridden it much. Besides, I'm always having to wipe off the oil so it stays clean that way!:laugh:
The Kaw List:
- PLUMMEN
- Thank you received: 104
