Engine Just Blew??
- steell
I have seen two things cause that, the most common is a clogged vent, the other is fuel in the crankcase igniting.
In your case I'd bet on a clogged/restricted vent.
- steell
As much as I like stock, I'll have to say you've done a fabulous job there on the MKII. Hope it works out as an easy fix.
High praise indeed, coming from the man that hates anything that's not stock
Almost went into shock when I read that post!!
- jordan
- Thank you received: 5
THAT BIKE IS FU@%(NG BEAUTIFUL!!!
its a bummer to hear about your problem, but i could barely take my eyes off of it to read your post. Great work.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Tony
- Thank you received: 13
Since I redid my top end I've re-torqued the head about 5 times. I checked the cylinder head nuts at about 10 miles, 50 miles, 200 miles, 500 miles and 700 miles. It wasn't until the last time they were all good.
Your bike really looks good!!
- 79MKII
- Love Them Kaws!
- Thank you received: 43
sand down the chrome on the gasket mating surface of valve cover to roughin it up when replacing gasket,chrome on gasket sealing surfaces sucks!:S
You don't mean sand off the triple plating do you? Just scuff it up, right? I wondered about that with all of my covers but tried it without sanding.
As far as the crankcase vent, I was definitely blowing a lot of oil with the ape low profile. I went back to stock with a longer hose and a filter on the end. No oil leaks now, so I don't think it's plugged. I see some exhaust exiting from the filter once in a while too.
My next question was going to be "what caused this"? I was thinking that my pressure must be high. I have heard that it will get better as the engine breaks in - have you guys heard that? Rings aren't completely sealed so there is more blow-by??
Also, aren't the factory Kawasaki gaskets rubber? I'd pay extra to get a good quality rubber gasket but I can't remember for sure. I do know that my old gasket was twice as thick as the new blue one.
Oh, and thanks for all of the compliments!
The Kaw List:
- PLUMMEN
- Thank you received: 104
- keith1
- Thank you received: 2
but i had to retorque cam cover bolts after running it post valve adj...i cranked them down initially, but after one run, they were loose as shit....just my .02.....keith.....p s...your bike looks sweet...i can appreciate the stock way of thinking, but i can also appreciate a nice @#$%$# ride!!!!
- keith1
Oh, almost forgot...
The swingarm is from Klasmo in Germany. I had them make a 6" over version and move the shock mounts back one inch. They now list it on their site. I bought it several years ago though when the dollar was still real money. It would cost about $900 right now, compared to about $650 when I bought it. Shipping has gone way up too. I'll post a link if I can find it.
Found it - here it is:
Swingarm Link
i think american classics sells those....nice pcs
- keith1
i was going to purchase the lo-pro breather untill i read about oil probs...i use stock with a piece of hose with a k and n that ends just past the pods....works well and in hot weather i see smoke out of filter when i rev it up......i use the same blue gasket and it seems to be holding up o k,
i just went to garage for shits and giggles and cam cover bolts needed just a tad more....keep an eye on those blue gaskets!!
- timebomb33
I THINK MY POWERBAND BROKE
- 79MKII
- Love Them Kaws!
I really liked the Trac arms but they were quite a bit more at the time. I think around $900?? I probably would have gone with it anyway, but the jerks answering the emails really ticked me off. Their customer service really seems to be terrible. That's what finally turned me off Trac.
The American Classix arms look to be from the same company, but only come in stock lengths. I'm guessing American Classix gets theirs from Germany too.
I also found quite a few arms for much less but they were the type without pivot bearings = no shocks.
The Kaw List:
- 79MKII
- Love Them Kaws!
...i always run two breathers on big inch motors...
Where to you run your second breather? From the starter hole? I had one there for the 1229 but put the starter back in on this rebuild.
The Kaw List:
