- Thank you received: 337
Engine Just Blew??
- bountyhunter
PLUMMEN wrote:
My next question was going to be "what caused this"? I was thinking that my pressure must be high. I have heard that it will get better as the engine breaks in - have you guys heard that?
The motion of the pistons does pressurize the crankcase as they move up and down. There is a crankcase vent, but there is still some pressure. BTW, I had a valve cover leak too and start dumping oil once upon a time. That's why I usually use a thin line of black Hi-temp RTV to bond them.
79MKII wrote:
Thyey are rubberized fiber with a rubber coating on the outside. They are better than aftermarket. An OEM cover gasket can usually be taken on and off a couple of times if done carefully.PLUMMEN wrote:
Also, aren't the factory Kawasaki gaskets rubber? I'd pay extra to get a good quality rubber gasket but I can't remember for sure.
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Hopefully that will solve my oil leak and then I only have to find out why it was running so badly. The plugs all look pretty decent, so no fouled plugs. I also tested the gas cap vent and it works great. I hope to try again with another ride tomorrow.
The Kaw List:
- steell
While one pair of pistons is moving down, the other pair is moving up, so they just push the air back and forth between them, the displacement of the crankcase never changes.
The crankcase vent is to allow piston ring blowby to escape
The KZ twins do pressurize the crankcase, then create a vacuum, because both pistons move up and down together.
- PLUMMEN
- Thank you received: 104
79MKII wrote:Thyey are rubberized fiber with a rubber coating on the outside. They are better than aftermarket. An OEM cover gasket can usually be taken on and off a couple of times if done carefully.PLUMMEN wrote:
- Sandy
- Fly High,Tony
- Thank you received: 13
RonKZ650 wrote:
As much as I like stock, I'll have to say you've done a fabulous job there on the MKII. Hope it works out as an easy fix.
High praise indeed, coming from the man that hates anything that's not stock
Almost went into shock when I read that post!!
Took the words right out of my mouth!
(hey...isn't that a song?:huh: )
Ron...we're cathin on to ya,bud.
That IS a beautiful machine though...wholly doodles!
I've never seen a valve-cover gasket do that before.I don't think you could even blame that on over torquing.
Is it possible,that it got torn during installation?(first thing that came to mind).
(edit)...just looked at the picture again,and I can see that the gasket was not torn...hmmm.
1977 KZ1000 A-1
- 79MKII
- Love Them Kaws!
[...I've never seen a valve-cover gasket do that before.I don't think you could even blame that on over torquing.
Right, it never did tear. It just distorted real bad and slipped out. I think it had to have been from crankcase pressure. Hopefully it will get better as it breaks in. The new gasket is installed with Hi-Tac and a roughed up cover, so it should have a much better chance of staying put. The bolts were still tight when I removed the cover. Here'a a better pic with the cover removed:
The Kaw List:
- Thank you received: 797
i hope this is the cure for yours though.to nice a bike to leak oil:P .
- APE Jay
- Banned
- Thank you received: 58
Oh, almost forgot...
The swingarm is from Klasmo in Germany. I had them make a 6" over version and move the shock mounts back one inch. They now list it on their site. I bought it several years ago though when the dollar was still real money. It would cost about $900 right now, compared to about $650 when I bought it. Shipping has gone way up too. I'll post a link if I can find it.
Found it - here it is:
Swingarm Link
High end American made chrome moly arms are about 1/2 that much
- Jeff.Saunders
Are you still running stock cam cap bolts? If not, make sure the heads are low profile heads. If you've used allen bolts for the cam caps, these will likely sit too high - holding the cam cover off the gasket slightly.
As the rings are new, they may not have bedded in yet - this will allow more ring blow-by than normal.
I had a similar issue a few years ago - I pickup up my first turbo'd KZ. The previous owner put some additional ports in the valve cover - but they look crappy, so I put a stock valve cover on the bike - big mistake, the bike puked oil out just about all the gasket surfaces...
www.z1enterprises.com
Z1 Ent on Facebook,
- APE Jay
- Banned
Jay
- 79MKII
- Love Them Kaws!
Swingarm Link
Jay,
Where can you get these? Do they have pivot bearings?
Thanks
The Kaw List:
- 79MKII
- Love Them Kaws!
The cam bolts are stock - shouldn't be a clearance issue. My old gasket was twice the thickness, but this should be OK too, I would guess.
The machining was done by S&K racing in Ohio and I did the assembly myself. It is a stock block with LA sleeves that I had put in 18 years ago by a local builder. I never had any oil leaks with the 1229 kit in all of those years, but I also had an extra vent in place of the starter. This time around I had the 1229 bore increased to 1260, the max for these sleeves and a stock block. S&K also did all of the headwork.
Do you guys agree that the crankcase pressure will decrease as the engine breaks in? I only have about 50 miles on the rebuild so far.
The Kaw List:
