- Thank you received: 337
Engine Just Blew??
- bountyhunter
I know, I watched the oil blowing out of mine when the gasket cracked....
The KZ twins do pressurize the crankcase, then create a vacuum, because both pistons move up and down together.
- mark1122
- Keep twisting it
- Thank you received: 109
The blow by will improve as the rings seat.
But the fact is as u increase cc's u are going to get more blow by.
As the ring start to where as u increase mileage the blow by will again , increase. the added crankcase pressure will increase the likelihood of oil leaks.
Do yourself a favor and increase the crankcase venting now.
There are a few dif ways, Kick start hole ,added vent on cam cover, oil fill hole. I chose to increase the capacity of the stock unit. Hear is a link to my project , it shows my added vents.
Pg, 5,6.
If u want to go with the kick start hole, i will give u the parts and filter .
kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=80
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Does anyone know (maybe ape jay??) if the APE low profile cover vents more pressure than the factory kz breather? I'd be willing to go back to it and run a hose to the back of the bike if it would help. I only took it off because it was spewing oil out of the filter on the end of a short hose.
The Kaw List:
- bountyhunter
Your ticket has scared me away from that one! I never would have guessed you could get a ticket for that. What a crock.
I once got a ticket for having a smudged driver's license.... not license plate, driver's license. I wanted to ask the little dork how he could see that with it being in my wallet and all... but figured I would be wearing a flashlight handle if I did.
- mark1122
- Keep twisting it
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
The Kaw List:
- Thank you received: 2098
The maze in the breather supposedly separates most of the blowby gas from the oil mist, allowing the oil to return to the crankcase and the gas to be drawn through the breather hose into the air cleaner housing and back through the carb intake.
Perhaps without the baffles, the oil mist and gas blowby could both be expelled to the atmosphere without any separation involved (to EPA's horror).
Good Luck!
- mark1122
- Keep twisting it
I agree .the baffles are important to separate and return the oil to the case. U also need a larger vent to reduce the presure. Larger vent tube = less velosity, more volume.Per FSM, the oil breather serves two functions: (1) minimize pressure variations from piston and crankshaft movement, and (2) recycle blowby gas from combustion chambers to keep it from contaminating the engine oil.
Good Luck!
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
I have the OEM breather but the hose is nor more than 3" in length to the filter...
I looked this up at Babbit.com but they don't show this hose and filter in the fiche files.
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
Out of curiosity, how long should the tubing be (OEM) to the filter?
OMR
It's an "S" shaped hose from top of vent to bottom of air box.
Here's the image from Kawasaki.com
[Click on image to enlarge view]
- Old Man Rock
I saw that but didn't put the two together. This old girl didn't come with the OEM air cleaner... DOH! Actually, didnt come with pods either.
Learn something new everyday, have to love it. Maybe some day when I'm old and gray and I'll actually know something about these old monsters. LOL!
Kudos...
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
