- Thank you received: 2098
1979 MKii No workie...
Good Luck!
- 79MKII
- Love Them Kaws!
- Thank you received: 43
Would first test ride with fuel tank cap ajar to determine whether this has any effect on the problem. If so, then worry about clearing the vent.
Good Luck!
Precisely!!
The Kaw List:
- monkonmonk
- 1979 MKII
I set out tonight with the electric starter not working. I checked the battery and got full voltage. So, I moved to the kick starter and first kick she roared to life. I let the bike run for 5-10min to warm up a bit. It idled fine and I revved the motor a couple of times with no issues at all. I got on the bike and headed to the next neighborhood over in case it stalled again, I wanted to be close to home. I had no issues riding around the neighborhood, so I moved on out to the open road. I headed down the road and probably made it about a 1/2 of mile and then I was rolling along at about 60mph and the bike just started to slow down.
I tried down shifting and got nothing. The bike just died. It was not like running out of gas where the bike studders or surges. I tried opening the gas cap, riding with it open, made no difference.
As soon as I stopped I tried to kick it over and the bike did nothing. It was as though I did not have spark or anything. I tried messing with the petcock from prime to res to on.
I was wondering if there could be something that got too hot while the bike was running that would overheat and quit working. I just think there could be something that I am not thinking about.
The reason being, as soon as the bike would sit for a bit or something, I would turn the bike on and give it a kick start and up and away she would go for another 1/2mile.
So, close guys, has to be something dumb.
Thanks,
Jason
- monkonmonk
- 1979 MKII
the first time that it quit on me, i pulled over to the side of the road and waited it out as always seems to be the case. When I finally got it started again, I took off. I thought maybe if it was a fuel line problem I could "Rev" through it. I took straight to 6k rpms where it promptly died again and I pulled over 30 yds down the road.
The weird thing is, that idling does not seem to be a problem.
Jason
- Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- 79MKII
- Love Them Kaws!
Have you checked your coils? My police bike was doing this exact same thing. I finally checked the coils out. Sure enough one was bad. I guess when it got hot enought it cuased it to short out internally or something. So I replaced them with dynas 3 ohm coils. Fires off in about one revolution of the starter now....
He's actually already got the dyna 3 ohms on there, but what's to say those can't go bad? I'm thinking it might be fuel starvation, but very well could be ignition. Like you said, it gets hot and shorts out, then cools off for a while. Very interesting...
The Kaw List:
- Bullitt03737
- Bullitt03737
- monkonmonk
- 1979 MKII
What other things should I be checking?
Jason
- 79MKII
- Love Them Kaws!
Could be float level too, but we're giving WG the benefit of the doubt on all carb issues.
The Kaw List:
All this because sometimes crud or grit is suspended in the fuel inside the tank. Where it is drawn to and hovers around and collects on the petcock intake tubes up inside the tank. This can restrict fuel flow and result in the problems described (akin to a blocked fuel cap vent). Same with a dirty partially blocked in-line fuel filter.
Am still harping on the fuel supply aspect because fuel starvation (from any of the above reasons) is IMO far more common and therefore much more likely than a cycle of both coils overheating enough to fail and then cooling off a little. Coils might end up being the answer here, but am still betting my nickel on fuel starvation instead of faulty coils.
Anyhow, it can't hurt to assure an ample supply of good clean fuel to the carbs.
Good Luck!
Good Luck!
