- Thank you received: 4
Uh oh, losing power above 5K
- freebyrd24
i installed the new coils and wires and still have the same damn problem. plugs 2 and 3 will not fire. point gap is perfect and identical to the 1+4 points gap. wiring is tight and all grounds are tight.
i tested voltage again by turing the key on and reading the voltage at the poles. on the 1+4 coil, i got a reading of 9.27 volts on each pole. On the 2+3 coil, i got a reading of 9.27 on one, and .4 on the other pole. These are the same readings i recieved before with the other coils.
i don't know where to turn next. it has to be some kind of electrical problem with the way 2 and 3 both are having the problem together
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- freebyrd24
i feel like an idiot
I had the points cover open and decided to check it the points were producing spark. One wasnt and one was. I look over at the one that wasnt and saw the two wires the connect to the point. One wire that goes up to the coil, and the other that goes to the condenser
These two connect tot he point with two flat plates. (those who've seen it or done points know what im talking about). One of those metal tabs that was connected to the point was touching the metal backing plate!
I loosened up the connection, moved it off of the backing plate, tightened it up and it fired on all four cylinders. I am a moron
Thank you for all your help everyone
Sold:
- freebyrd24
I still have no power over about 4.5-5 thousand RPMS. Its just running poorly above that
Sold:
- Thank you received: 2098
The 9.27 volts to coils is too low. Either the battery is low or there's a deficiency in the wiring and/or connections between the battery positive terminal and coil. Battery condition should be unquestionably good (fully charged and able to hold the charge). Further testing with a low battery or with too low voltage getting to the coils is fruitless. Could charge the battery and then do a specific gravity test or just take it somewhere (automotive parts store) and have it load-tested. Maybe it's time for a new battery, but am doubtful that the existing battery was harmed by the hard acceleration episode. If the battery is good, remember about testing with addition of a temporary secondary wire direct from battery positive to the coils (to assure full battery voltage to coils).
Meanwhile --- Have valve clearances been checked? If so, are they up to specs? Remember, the compression test alone is not enough, as it may show just fine before the engine attains normal operating temperature. Marginally too tight valves may seat during compression testing, but fail to seat at operating temperature (that's the reason for the gap).
It's also conceiveable that a valve spring was broken or weakened during the hard acceleration episode. A leak-down test could also be helpful toward better pin-pointing a reason for less than perfect compression, as it should indicate any seating weakness in a particular valve.
In brief, would (1) assure good battery with (2) full voltage to coils, and (3) assure valve clearances to specs, and (4) clean and gap points, (5) re-check ignition timing, then re-test performance. And if problem continues, (6) replace points with DynaS ignition.
Keep the faith!
Addendum -- Z1E Leak-Down Tester
- freebyrd24
I'll try running a wire from the battery to the coil and check voltage to make sure thats not the issue. The battery is in excellent shape and fully charged, but always a good idea to check.
i haven't checked the valve clearances at all. It's honestly a pretty intimidating task to me based on my readings of it. How do you perform the leak down test? I've seen it mentioned a few times on here, but am not sure how
Sold:
The leak-down test requires a special tool which is an apparatus whereby air pressure is introduced into the compression chamber while both valves are seated (closed). Then listening to where the air escapes. If heard coming out the exhaust, the exhaust valve is likely leaking. If heard coming out the carb, the intake valve is likely leaking. If heard coming out the crankcase vent, compression is slipping past the piston and rings. For those interested, I believe Z1E carries the leak-down tester. Many of us amateurs don't have a leak-down tester in the toolbox.
Where using the compression test alone shows poor compression, the loss of compression may be from (1) either or both valves failing to fully seat for whatever reason (often cured by adjusting clearance) or (2) from getting past the piston and rings. Where valves are seating okay, adding some oil inside the combustion chamber often raises the compression figure by temporarily preventing compression from getting past the piston and rings. Where adding oil doesn't substantially increase compression, the piston and rings are likely okay. Happily, many low compression issues are resolved by adjusting too tight valve clearances to specs. The over-bucket style shims (Z1, KZ900/1000, large fours) are easier to adjust because cam removal is not required. My understanding is that under-bucket style allows higher rpm's without spitting out a shim.
Will maybe lose, but right now am betting my nickel on the fix being full good battery voltage to the coils plus clean/gapped points and verified timing. And willing to go double-or-nothing with the DynaS ignition. :lol:
Good Luck!
- wiredgeorge
Here is what I would do. First, I would check the reg/rec and general charging of the bike. Take off the seat or lift it up. Start the bike. Put your multimeter probes on the battery poles... red (pos) to the positive battery terminal and black (neg) to the negative battery terminal. At idle, you should see about 12.5VDC or perhaps just a shade lower. Rev engine to 4K rpm. You should see 14.5 VDC. If you see significantly more or perhaps less, you have a problem in the charging system. If you have less, this is REALLY contributing to your lack of power.
If you have 9VDC available with the engine not running, you are getting 3/4 of the power you should because of the path that the power takes to get to the coils... switches, connectors, wires, etc. Read my coil repowering article on our website under wg's Tech Stuff Index.
I don't think there is anything wrong with your coils and the problem with the points only masked the underlying problem. If the quick electrical stuff I recommended doesn't fix the problem, then the full tune up stuff that has been suggested is in order; you should do it anyway but your coil voltages are so low, you can't get good spark. Period.
- freebyrd24
Sold:
... Lack of voltage would cause upper RPM problems as it needs more power correct?
Yes. But remains a mystery to me why the hard acceleration episode seems to have so instantly and directly caused the problem. Betcha you're gonna really be pissed if find a crusty, loose or ill-fitting connector somewhere between the positive battery terminal and the coils.
Remember to clean and gap the points and then re-check timing. If the condensor was damaged by shorting against the backing plate, I believe (but am not positive) the points will still perform okay, but be subject to more arcing and burning because of the bad condensor.
Am still thinking the hard acceleration episode caused something to vibrate loose in the ignition, whether in the points connections or other wiring.
Good Luck!
- freebyrd24
running the bike at 4K RPMs, voltage maxed out and maintained a 14.76 volts. when back at idle, voltage maintained a constant 11.8 volts. While the bike was running at idle, i measured the voltage at the coils, the coils had a voltage of about 10.01 volts.
is this acceptable or is this number too small?
Sold:
some quick electrical test results...
What is voltage at the coils at 4K RPMs?
- freebyrd24
Sold:
