Uh oh, losing power above 5K
- wiredgeorge
At some point, you should start doing some pointed troubleshooting where your efforts will point to the actual problem.
How did you measure resistance on the coil wires? To measure primary resistance, put your probes on the lugs where the small wires are connected in Ohms scale (lowest). Measure secondary resistance (you have TWO sets of windings and the secondary can be shorted) on the contacts for the the spark plugs or if you can remove the wires, on the contacts where the wires connect to the coil. Put the meter in Ohms scale on a much higher scale since you will be looking at 10-20K Ohms.
- freebyrd24
- Thank you received: 4
i measured resistance as the book stated. i took out my multimeter and measured ohms. I removed the coils and put the leads for the secondar resistance on the side that connects to the spark plug wires. I forget the exact number, but it measured within spec and both coils were equal.
For primary resistance I put the leads onto where the wires from the harness connect to the back of the coil and i got a reading of 3.0 ohms on each. However while the wires from the harness were connected to the coil, I recieved a reading of 3.0 on one, and only .8 on another. I do not know what significance that plays
I traced to the points to see if they were in spec, and one set of them had damage. On side of the contact was missing some metal, while it appeared that missing metal had melted to the other side, so i replaced them.
the coils tested out okay so i have eliminated that as the problem. I also have brand new plug wires and plugs.
i do not know how to proceed or what to test next. I am doing troubleshooting to find the problem, and it has been logical, but I cannot find the source of the problem
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- freebyrd24
Also I checked spark across all 4 plugs just now and only 2 and 3 have spark. The bike is no longer running or starting. I have no idea whats going on.
Sold:
- bountyhunter
- Thank you received: 337
Both the 2&3 pipes are cold, 1 and 4 are firing. I could touch them upon initial start up and it was clear
Unless you have a tester which can fire them under load, you can't test them. Coils are high voltage transformers and the secondary windings have to be able to handle at least 60 KV in modern applications. The insulation on the windings will break down over time and show up when running, but not always with an Ohm meter.
The condition of the points you describe indicates that the coil may have been bad and causing an excessive voltage to appear at the points. There could be another problem, but based on your description, that sounds like coil damage.
You said above:
the bike has has new points, new condenser, new plugs, new wires and its running off of cylinders 1 and 4 only. I switched the coils to see if it was a coil, and it did the same thing, so not a coil problem
Clearly, something took out the points. Try installing a good set of points and running it. Then, try swapping the coil and see if the two "dead" cylinders start running with the coil from the "good" cylinders.
- freebyrd24
The one that originally did not fire 2+3 then fired # 1+4. i mean could it still be a coil issue?
Sold:
- bountyhunter
Does your bike have one set of points or two?
- Mellvis
- freebyrd24
what would switching wires on the condenser do?
Sold:
- Thank you received: 2098
While the outside appearance of the wire may look perfectly okay, the inside wire might be frayed or broken underneath the insulation. May use an ohmmeter to do this test, which is basically to assure integrity of the inside wire.
While doing the test, manipulate the wire and wiggle it all around to see if the ohmmeter jumps, which would indicate an intermittant connection. And which could result in intermittent power to the coil primary winding.
Good Luck!
- wiredgeorge
