- Thank you received: 4
Uh oh, losing power above 5K
- freebyrd24
After whoaing it up, it wouldn't accelerate well after 5K. It seems like the bike is not running on all 4 cylinders after 5K, or under any real load. I can drive up to 4K no problem nice and smooth. Definately on all 4 cylinders and running smooth. This bike has been fast and reliable for years now with me. It was in great running condition and never had a problem with it. I've also had it out of winterization for a while now. It was just after that moment of hard accelerating that its acting up.
I changed the spark plugs thinking one may have burnt out but that did not help.
Any ideas???? Thanks
- 1981 KZ1000-K1 LTD - Long term project
1075cc Kit - New Wiseco Pistons
Sold:
- 1978 kz650 SR, 4-1 Vance and Hines Full Exhaust, Dyna-S Ignition, Accel Coils and Wires
- anarki650
- Thank you received: 5
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- wiredgeorge
- bountyhunter
- Thank you received: 337
So today was 70 degrees here in mass! I was leaving work and halfway home i had a nice long stretch of open road. I put it to red line in first and second and third, and shifting to 4th, it stayed at 7k and wouldn't accelerate. And its an SR so redlining 3rd isn't that fast.
I had similar symptoms once after getting bad gas that rusted my tank. I flushed it and put in good gas, but rust particles would sometimes get into the main jet and it would lose power.
- freebyrd24
I may have to take the carbs off as well. which is a royal pain with stock airbox! So I'll try to rule out most other things first.
Sold:
- freebyrd24
I finally got some time to tinker around some more with the bike. I was thinking maybe something with the coils so I decided to check the resistance as specified in the book.
The primary (winding?) resistance to my understanding is the resistance of the leads that go to the coils. a yellow/red wire and green on one side, and a yellow/red wire and black on the other. They are supposed to be at about 4.0 ohm resistance as the book states. The side with the green wire has a resistance of 3.0 ohms while the side with the black wire has a resistance of .8 ohms.
What does this mean??
Oh and compression was excellent, as was the advance mechanism
Sold:
- Thank you received: 2098
Sometimes crud hovering inside the fuel tank settles around and clogs the petcock intake tube screens which go up inside the tank.
While stopped trying to figure things out, enough fuel may trickle into the float bowls allowing normal operation for a short distance before again "running out of gas."
Hoping for a cheap and easy fix.
Good Luck!
- freebyrd24
Sold:
- freebyrd24
the fuel system is completely clean. the filter is extremely clean, its not a fuel issue
the bike has has new points, new condenser, new plugs, new wires and its running off of cylinders 1 and 4 only. I switched the coils to see if it was a coil, and it did the same thing, so not a coil problem
any ideas on why its running on only two cylinders?
Sold:
- bountyhunter
If you have spark, pull the plugs and check for fuel in the dead ones. if you have spark and feul, it should run. You should also check compression across all four.
- freebyrd24
I'll try to check voltage to the coils and continuity to the points. whats the easiest approach to checking both of these?
Sold:
