- Thank you received: 4
Re-Installing Camshafts Problem
- FloridaBiker
- FloridaBiker
Post edited by: FloridaBiker, at: 2008/01/15 08:27
- madderkaw
- Thank you received: 8
- Little B
- Thank you received: 3
On my bike you have to have the "IN" line on the intake cam pointing between the 45th and 46th pins.
Well, into the garage to expand the project! :laugh:
1981 KZ750-H2 LTD
- steell
So:
(1) The cam chain tensioner wasn't locked and extended, thus taking up all the slack, or:
(2) The cam chain is not in place on the crank sprocket.
Normally, when you remove the cam cover on a 750 four, one of the cams will move due to valve spring pressure causing it to rotate, and it seems to always take the slack out between the cams.
Personally, I always remove the tensioner prior to removing the cam cover, makes it easier to put the cam cover back on.
- Little B
The 750 fours have a cam chain guide in the top of the cam cover that pushes the cam chain down, so if you lock the tensioner there will be slack when you remove the cover.
Well, I guess I locked it properly because there was slack in the chain when I took the cover off initially.
However, if the chain isn't on the crank sprocket properly, is there a way to get it back on?
Post edited by: Little B, at: 2008/01/14 17:56
Post edited by: Little B, at: 2008/01/14 17:57
1981 KZ750-H2 LTD
- RonKZ650
- Thank you received: 240
- jordan
- Thank you received: 5
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
- Little B
I wound up taking the tensioner off and the camshafts fit right in there w/o issue.
Now I have a potential timing issue I need help with. :blush:
The instructions are as follows: "With the crankshaft positioned so t#1 and #4 pistons are at TDC, check that the timing marks on the exhaust and inlet camshaft sprockets are aligned with the cylinder head surface. When I do that, this is what I get:
Exhaust side the Z7EX mark line is what is supposed to be aligned.
On the intake side, the IN mark line is supposed to be aligned.
As you can see, they are a bit off. My question is, is this normal or do I need to make an adjustment somewhere? If I continue turning the crankshaft around until those marks are exactly flush with the cylinder head surface, the timing mark is about 1/4" further clockwise from the proper position.
Note: The IN line is pointing in between the 45th and 46th pin as the manual says to do.
The other possible problem I have is that when I continue to turn the crank clockwise, there is a loud 'click' release sound and the cam chain at top gets a huge sag in it. It looks like this:
I notice that if I put pressure on where the tensioner will be it doesn't do it as bad but I still feel the chain 'release' as it goes around. Is that normal? If so, why does it do that?
1981 KZ750-H2 LTD
- Little B
1981 KZ750-H2 LTD
- RonKZ650
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Once your exhaust cam is in position, install the intake cam with the alignment arrow facing directly backward at the rear head mating surface. Then count the pins starting with the pin above the exhaust mark as #1. Count out the specified number of pins and make sure the intake mark is aligned in the proper location.
Then count again. Then one more time, just to be sure.
Next, install the cam caps and bolt them down. In my experience, at this point, there will be some slack in the chain between the cams. With a wrench (or socket), slowly turn the engine over from the ignition side. Use your hand pushing down on the chain between the cams to keep tension on the chain so it doesn't jump a tooth. When you come back around to 1/4 TDC, the chain should be taut between the cams. The timing marks should now both line up with the mating surface, front and back. You can then reinstall the tensioner.
And recount the pins ONE MORE TIME.
West Linn, OR
