- Thank you received: 3
Re-Installing Camshafts Problem
- Little B
There is no slight 'sag' between the sprockets like there was before I removed them. Notice how the intake is bent out on the right side? The red thing is just a WD-40 spray straw that I'm using to count the links. Any ideas?
Another thing the manual says to do is check to make sure the chain is in the front and rear guide. However, I don't see any way to see down there well enough to check because the frame is in the way. Is there some magical way to do this too?
1981 KZ750-H2 LTD
- steell
- Little B
Chances are you don't have the chain in place on the crank sprocket.
When I had the cams out, the chain was very loose so I could see how it could have come off somehow. But, how do I go about checking that and fixing it if its an issue?
1981 KZ750-H2 LTD
- kawsakiman
- Thank you received: 6
- PLUMMEN
- Thank you received: 104
yeah that would be my stupid question ! or its balling itself up around crank sprocket;)did you remove the cam chain tensioner?
- Little B
No, I didn't remove the tensioner. I did lock it with a long bolt though. Are you supposed to remove the tensioner completely before re-assembly? The manual doesn't say that but maybe I missed it or something? Thanks for the help guys.
1981 KZ750-H2 LTD
- modprod
All these "Automatic Compensating" style camchain adjusters have to be removed and "reset" before you reinstall the cams. When you even loosen the cam caps enough to allow the camchain to allow slack at the back, you must remove and "reset".
- Little B
Is that true even if it is locked before removing the cams initially?
1981 KZ750-H2 LTD
- modprod
Post edited by: modprod, at: 2008/01/14 01:43
- Little B
The "hold-down" bolt is always supposed to be locked down after you first releases it after being "reset" to to start position. It should descibe this proceedure in a manual.<br><br>Post edited by: modprod, at: 2008/01/14 01:43
I guess what I don't understand is why I'd need to remove it if I installed a 6mm bolt which made it so that the push rod couldn't move in further to take up the additional slack?
The manual does explain how to lock the tensioner and says to do so before removal of the cams or anything else that will slacken the chain. I did this before even removing the valve cover so I wouldn't think that the tensioner would have moved in any further than it was before I removed the cams. The manual only instructs to lock the tensioner, not remove it. ?? :S
Is it because regardless of how far the push rod is in there already it is something that the chain has to go around?
1981 KZ750-H2 LTD
- PLUMMEN
- modprod
Post edited by: modprod, at: 2008/01/14 02:21
