Wrecked my 81 Kz750ltd
- dom2570
19 Apr 2015 09:42
Long story short I hit some gravel and lost control. No major injuries, but I did destroy the front rim and timing cover. I already ordered a rim, but am having one hell of a time tracking down a timing cover. Any help would be much appreciated!
Whip it like a mule!
- dom2570
Re: Re:Wrecked my 81 Kz750ltd
19 Apr 2015 11:09
Just realized I messed up the title. It is an 82, not that it really c matters
- Mellvis
19 Apr 2015 11:12
Bikes can be fixed. just happy you are ok. A quick search on Ebay should find the cover pretty cheap. Good luck on a speedy recovery for you and the bike.
- DoctoRot
19 Apr 2015 11:28
Gravel, the street bikers worst enemy. I did the same in a parking lot last summer, totally caught me off guard. luckily i had case guards on so damage was minimized, $100 worth of parts later you can't tell. :whistle:
19 Apr 2015 11:48
Case guards are a must.
- Old Man Rock
Re: Wrecked my 81 Kz750ltd
19 Apr 2015 13:40 - 19 Apr 2015 13:45
No eBay APP ID and/or Cert ID defined in Kunena configurationNot sure if clutch cover took a hit so just in case...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 19 Apr 2015 13:45 by Old Man Rock.
- Old Man Rock
19 Apr 2015 13:48
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- DoctoRot
19 Apr 2015 16:59
those are two different clutch covers completely. one is a twin and one is a four
19 Apr 2015 17:41 - 19 Apr 2015 17:48
Assuming a 750-4. A bunch of models used the same pulsing coil cover or are interchangeable.
Any 750-4. For sure the 750E/H & 81-83 KZ650-CSR. The 83s are slightly different cosmetically. KZ700. Probably the ZN700/750. Maybe the 90s ZR750. And maybe the KZ550 --- not sure on the 550. An easy check is to see if the gasket is the same, but even then compare to make sure it's not too shallow (non-stock part but probably not an issue), so check the diagrams at Partzilla.
Last edit: 19 Apr 2015 17:48 by martin_csr.
- dom2570
22 Apr 2015 13:03
I found a cover. Now how do I fix this missing chunk?
22 Apr 2015 13:18
You were lucky there. You can have it built up by welding or JB weld. It's on the bottom so it won't show. If I had case guards they could have saved my covers.
- dom2570
22 Apr 2015 14:44
I have been looking foe case guards on and off for over a year. I will definitely pick some up as soon as funds allow it.
You can't tell in the picture, but the "magnet thing" someone please correct me, was damaged. I have one from a kz1000 and it fits my kz750. Any reason why this wouldn't work?
