- Thank you received: 27
Wrecked my 81 Kz750ltd
- dom2570
Whip it like a mule!
- Randombeat
- 0 to 100 real quick...
- Thank you received: 23
dom2570 wrote: 1000 on the left 750 on the right...
They sure look identical... Happen to have part no, or any #s on them?
1980 KZ750H LTD-- pods-- vance & hines 4-1 --speedo/tach/blinker/switch deletes -- brat style
- fixitmann
- Thank you received: 10
LOL beat me by a few seconds......
So the old Rocker gets out his bike to make a ton before he takes his leave. Up on the A1 by Scotch Corner
just like it used to be. And as he flies --- tears in his eyes ---
his wind-whipped words echo the final take and he hits the trunk road doing around 120 with no room left to brake.
- Thank you received: 1656
- zukdave
- Thank you received: 229
oil pressure sending unit.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- dom2570
- dom2570
- Randombeat
dom2570 wrote: Used some JB steel stick to fill in the missing chunk. Then mounted the new rim and everything else. She fired right up for me. I should get the timing cover tomorrow. The. All that is left is new bars, as these bent.
What kind of bars are you gonna go with? Rentals would look cool with your setup...
- dom2570
I got the side cover today. It was gold and ugly at first, but sanded down really nice.
- dom2570
I went through the wiring and replaced a lot of wires, sanded and polished terminals and attempted to clean it up as much as I could. I tried to remove the fuse box and replace it with an automotive blade box. It worked absolutely great...until I got caught in the rain...Luckily I had an old box to switch back to till I sort out the kinks.
I replaced the plugs, ordered new plug wires, and valve cover gasket. Once the gasket gets here I will be adjusting the valves.
I have a dent in the tank I want to try and get taken care of, then I am going to clear coat it. I have fallen in love with the rust look...
Attachment 20150504_161624.jpg not found
- Tyrell Corp
- Thank you received: 261
Martin, yes the 550 covers do fit.
