Z2 750 crank (Bossie the Kaw)
Re: Z2 750 crank (Bossie the Kaw)
11 Sep 2019 16:29
Just going to do a light cleanup on the ports.
16 Sep 2019 07:15
Cleaning up the head for welding.
16 Sep 2019 14:20
One step closer.
17 Sep 2019 06:40
Two steps back. looks like I need exhaust valves.
17 Sep 2019 20:45 - 19 Sep 2019 19:05
The valves are junk. :dry:
Last edit: 19 Sep 2019 19:05 by SWest. Reason: Edited video
28 Sep 2019 12:44
Won't be long until I tear her down again. Until then she's running good.
30 Sep 2019 08:21
Dug out some old Splitfire plugs I had in a box. Good plugs.
06 Oct 2019 07:30
I think I found a few gremlins.
06 Oct 2019 08:52
No eBay APP ID and/or Cert ID defined in Kunena configurationI ordered this to replace my HID. Should have it Monday.
06 Oct 2019 13:20
Hi Steve, I just completed an Halogen headlight conversion, during the front end, gauge and fork rebuild, but not real happy with the output of the 60/55 H4 bulb. To me it doesn't seem much brighter than the original Stanley sealed beam. How does this bulb compare? Looks like it would fit in the Halogen conversion carrier? Would any other changes need to be made to the charging system to use this bulb?
06 Oct 2019 15:12
It is supposed to be plug and play. Should get it tomorrow. I'll post a clip about it. Hopefully it'll last but I'm sceptical about it.
08 Oct 2019 20:38
Nice to have a new cable. I forgot how easy it was on the clutch hand. I started a thread on the LED headlight.
