Z2 750 crank (Bossie the Kaw)
  • SWest
  • SWest's Avatar Topic Author
  • 10 22 2014
Re: Z2 750 crank (Bossie the Kaw)
09 Jan 2020 15:19
#816780
I hate to tear down a good running motorcycle but it has to be done.
(Continued from my Cam Tower Caps thread)
kzrider.com/forum/2-engine/611611-kz1000-cam-tower-caps
  • SWest
  • 10 22 2014
10 Jan 2020 06:52
#816822
I was right about fitting the caps to the Andrews cams.
  • SWest
  • 10 22 2014
10 Jan 2020 19:19
#816891
Getting the head off was a PITA. :angry:
  • SWest
  • 10 22 2014
11 Jan 2020 07:29 - 11 Jan 2020 07:30
#816905
Looks like this will be a good head. B)
Last edit: 11 Jan 2020 07:30 by SWest. Reason: sp
  • SWest
  • 10 22 2014
11 Jan 2020 13:54
#816931
Took everything off I need.
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
11 Jan 2020 18:52
#816939
Bossie is in good hands.
1982 KZ1100-A2/1170cc sleeper 😀
  • SWest
  • 10 22 2014
11 Jan 2020 20:29
#816943
Now to bench set the lash.
  • SWest
  • 10 22 2014
12 Jan 2020 20:39
#816993
This is going to take a while. :unsure:
  • SWest
  • 10 22 2014
13 Jan 2020 12:27
#817033
Doesn't look good but I'll use the best I have.
  • SWest
  • 10 22 2014
13 Jan 2020 18:31
#817057
Rookie mistake. :blush:
  • Mikaw
  • Mikaw's Avatar
13 Jan 2020 19:09
#817059
Help out a rookie... How did you bend a valve installing the cam???
  • SWest
  • 10 22 2014
13 Jan 2020 22:04
#817065
When setting the valve lash on the bench you can only use one cam at a time or risk one valve coming in contact with another. I forgot that. . :blush:
