- Thank you received: 36
helmet???
- mtbspeedfreak
mtbspeedfreak wrote: You should not buy a helmet without trying it on. I cannot stress this enough. If you ask nicely, you might be able to wear it for a ride around the block.
A few years ago, right out of college, I did not have hardly any money. I bought a cheaper DOT/Snell helmet. That f*cker was so loud from the wind at highway speeds it permanently damaged my hearing. After a year and a half, I finally manned up and started looking at proper helmets. I wound up buying an Arai. It wasn't cheap, but it fit better than I ever imagined a helmet to fit. I tried on virtually every make of helmet before making this decision.
I was not able to take it out for a test ride unfortunately, so I did my window noise/ventilation research online. I can't remember the website now, but I'll follow up tomorrow.
The Arai that fits me perfectly may not fit you. The Bell might not fit you. The Shoei/AGV/Scorpion/etc may not fit you. The only, repeat, only way to know for sure is to try them on.
Let us know what you choose!
Here's the helmet review site: www.webbikeworld.com/motorcycle-helmets/motorcycle-helmets.htm
Pretty good stuff, these guys know how to test a helmet!
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
2000 ZRX 1100
- mtbspeedfreak
turboguzzi wrote: even a top of the line helmet is going to create irreversible hearing damage at highway speeds.
regretfully, damage to hearing is cumulative, so every time you are exposed you damage your hearing a bit more and hearing deosn't heal itself with time.
always, always, always use ear plugs. I do so even for relatively short rides....unless you think that bad hearing is sexy somehow.
Helmets are interesting. 99% of the top of the line helmets are created for racers/track days and don't care about noise, just ventilation. The more vents a helmet has, the louder it'll be.
I have an Arai Vector 2 and have been extremely happy with it. Yeah, there is noise at highway speeds - not nearly as much as my previous Icon Alliance helmet. That being said, you definitely want to use ear plugs for more than around-town riding. I use a nice set of earbuds and music while on longer rides. They knock the dbs from the wind down and it's nice being able to pause and play the music when I want to.
2000 ZRX 1100
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- mtbspeedfreak
2000 ZRX 1100
- dejavoodo41
- RonKZ650
- Thank you received: 240
- dejavoodo41
- AnthonyMartello
Thanks a lot
Anthony
- turboguzzi
- Thank you received: 72
RonKZ650 wrote: I did my last big ride a month ago that was 1733 miles in 24 hours according to the GL1800 odometer, 1664 GPS certified miles and had my Arai on for 22.5 hours straight other than gas stops. I would challenge any less costly helmet be comfortable for this ride. Some of the reviews I think they ride 2 miles to rate these helmets.
Kudos on the big ride but comfort in a helmet is a very personal thing, tried Arai and it never felt good on my head while Shoei's always fit mine like a glove.
a friend that works in a gear shop used to say: there are the Arai heads, and the Shoei heads
- kzcurt
- Thank you received: 21
I guess i'm too cheap.... i'll wear my helmet for the 75.00 per bike it cost to buy the additional coverage. besides I'm way to accident prone to risk it!
Flag carrier #23
9 @ 50-2053,
- mtbspeedfreak
That has to be one of the dumbest motorcycle laws I've ever heard.
2000 ZRX 1100
