BHP vs Harleys
  • civilengr3
  • civilengr3's Avatar Topic Author
BHP vs Harleys
17 Jul 2009 08:15
#307567
Wow. I was comparing BHP on a Road King to my little 650. With a 1450cc it shows 67 bhp @ 5400rpm. When new mine was 64bhp@8500rpm. And I've got about 300 lbs lighter.
I've had this bike about a year, and all the time I was thinking it was kind of slow. But based on this I'd smoke a Harley. What's your experience? Stories are good ;)
1977 KZ650C
East TN
  • TexasKZ
  • TexasKZ's Avatar
Re: BHP vs Harleys
17 Jul 2009 08:31
#307569
You might want to look at torque output before you bet the farm on a race. Basically, torque = acceleration, horsepower = top speed.
  • otakar
  • otakar's Avatar
Re: BHP vs Harleys
17 Jul 2009 08:35
#307570
Harley has the torque. Top end he would most likely walk on you. Harley BHP is honest. Kawasaki BHP is BS. Put both on a Dyno and you will see. Your stock 650 would read about 45BHP at the rear wheel on a Dyno. The 83 GPz1100 which is advertised at about 120 BHP is about 80-85 on the Dyno.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
Re: BHP vs Harleys
17 Jul 2009 08:37
#307571
What He Said. :ohmy:
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Davestradamus
  • Davestradamus's Avatar
Re: BHP vs Harleys
17 Jul 2009 08:44
#307573
I ride frequently with an 09 Harley Iron 883 Sportster. It has 67hp and weighs in the 500lb range. I think the acceleration is about equal but we never drag raced. The kawa has much better handling mostly because of how low the harley is. I would be sad if my bike couldn't outrun a roadking. They are long distance touring bikes. It's got 6 gears and I am sure it would leave a KZ in the dust after 100mph though. I think the sportster is a cool bike and has a lot of potential but it's not really my style. There is a company in the uk that makes off the shelf sportster cafe racers. They look awesome, but I think am partial to the fourstroke four.
Holler black,
David
  • flht1997
  • flht1997's Avatar
Re: BHP vs Harleys
17 Jul 2009 08:51 - 17 Jul 2009 10:45
#307574
having both mentioned bikes, well not a road king but an electra glide, the 650 will walk all over a HD closest thing would be a 400/440 or a poor running 550 maybe as far as acceleration would be concerned. the 650 is in the mid 30's for max torque where the 1450 HD will be in the mid 80's. what this means when i ride my bagger is i shift at 3500 rpms cause it really does no good to twist it past that, get to 5th as soon as i can and leave it there and get an honest 49mpg running at 75mph. my HD "feels" the same whether i am solo or two up with a weeks worth of crap. and that would be slow, but ohh so comfy. :)
and the top end for a stockish FLH is about 110/115 mph or so thats at redline (5500) in 5th the new 6 speed one might be a bit more, but i think that a good running 650 will still out run one
Matt Milwaukee, WI
75' KZ400, (5) 78' KZ400, 76' KZ 750, 78' KZ650
78'CB750F, 78' CB550K
89' BMW R100RT
05' H-D Electra Glide
06' KLR650
Do it right or don't bother doing it at all.
Last edit: 17 Jul 2009 10:45 by flht1997.
  • Tyler
  • Tyler's Avatar
Re: BHP vs Harleys
17 Jul 2009 09:25 - 17 Jul 2009 09:33
#307576
Then there is gearing, and a stock geared 650 is very short next to a v twin cruiser. Look this is an apples to oranges comparison. The kz650, 750, and 900 are the birth of the the crotch rockets the first step to the GPZ's which lead to the Ninja's and the rest is history. The HD is just that, a Harley and does what Harleys do... cruise. I have smoked 130 cubic inch S&S motor with a late model tuned Suzuki 650, but I wouldn'd ride that bike for any long distance. That is what the HD is for. My brother has some shovel heads that were built to go down the strip, and any well set up modern sport bike can give them a run for thier money. V twin engines are antiquated technology, and suffer from an out dated and limiting design. V-twins have sound, and feel, and good torque, 4 cylinder engines have so many performance advantages it's not even a fair comparison. Back when that 650 was made it was state of the art, and though is may be 30 years old today it's engine is light years ahead of a v-twin design.
"74 Yamaha DT 400 Enduro
Last edit: 17 Jul 2009 09:33 by Tyler.
  • WABBMW
  • WABBMW's Avatar
  • Let The Good Times Roll !
Re: BHP vs Harleys
17 Jul 2009 09:33
#307580
civilengr3:
TexasKZ is right about the torque. The Harley has a much wider spread of torque through its RPM range, pulling strong from say 1,500 to 5,500 RPM. The KZ is low on torque until the RPMs are on up fairly high - say 5,000 to 9,000 RPM. But once the KZ gets wound up, it really shines. Also 300 pounds is a tremendous weight advantage for the KZ.
Let's say that both bikes are rolling along side by side, in 2nd gear, at a low RPM. As the race begins, the Harley will likely pull ahead, but as the KZs RPM builds, it will run stronger and stronger, gaining back the lost ground, and soon out accelerating the Harley. Then with the KZs RPMs up high, as he shifts to the next gear, the RPM will stay in the power band, leaving the Harley in the dust.
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
  • Tyler
  • Tyler's Avatar
Re: BHP vs Harleys
17 Jul 2009 09:38
#307581
WABBMW wrote:
civilengr3:
Thats exactly what I have seen. Not with a kz but and old GS.
  • Locozuna
  • Locozuna's Avatar
Re: BHP vs Harleys
17 Jul 2009 10:31
#307587
Don't it kinda depend on how many skulls and flames the Hurley has on it? :blink:
"Over the Mountains
Of the Moon,
Ride, boldly ride,"
The shade replied
"If you seek for Eldorado!"
  • 550A2
  • 550A2's Avatar
  • keep the shiny side up
Re: BHP vs Harleys
17 Jul 2009 10:41 - 17 Jul 2009 10:46
#307590
Yea tyler is right, ive lined up with a couple harleys on my 550 and they always get me off the line, but once up around 5 or 6 grand the power band kicks in and leaves them behind me..... I have to admit though, it feels good! my 1000 dollar 38 year old bike will kick the snot out of a new 20,000 dollar harley.
I especially like racing the guys that are decked out in all black and orange harley gear, hahaha. Some of them get pissed! when i look back and wave. im respectful though.
My dad has a 2001 1600cc yamaha roadstar with some porting and a big bore kit... nice bike. But he cant keep up either....
I love my little kz.
:side:
Eat some harley davidson jerky! ayyy!
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
Last edit: 17 Jul 2009 10:46 by 550A2.
  • Tyler
  • Tyler's Avatar
Re: BHP vs Harleys
17 Jul 2009 11:41 - 17 Jul 2009 11:44
#307595
Here is a modern bike shoot out. What looks like a built HD drag bike against a ZX-10R. The ZX got a late start but still ran down that v-twin beast. At Brainered MN, I saw some built v-rods get toased by Ducati's, Honda's and Suzukis that cost half as much. It's just the way it is...
I would still love to own a V-rod night special, damn sexy bike if you ask me.
www.youtube.com/v/yPojN2Mmuqo&hl=en&fs=1
Last edit: 17 Jul 2009 11:44 by Tyler.
