KZ650 Poll
- N0NB
- Blue handles better
Here's the SR:
And the 650B of which I need a current pic:
Post edited by: N0NB, at: 2007/09/16 15:15
Nate
1979 KZ650 (Complete!)
1979 KZ650 SR (Sold!)
1979 KL250 (For sale)
1994 Bayou 400 (four wheel peel )
- OnkelB
- Thank you received: 80
OnkelB: Gorgeous! Do you have more pics (like a 90-degree from both sides) and explination of work done? Bitchin' ride!
-KR
Thanks for the compliments, appreciate it. Here are a couple of side shots - as already stated it´s a 77 KZ650 B1, braced and powdercoated frame, dual front discs off a Z1R, front mag is from a 650 C (I think), Zephyr 750 swingarm, GPz900R rear wheel and brake, Harris 4in1, Henry Abe air filter, Kawasaki sports seat for a 900 adapted to fit, Clubmans upside down (the Euro style) and a set of Paolo Tarozzi chrome bar weights, Wirth progressive front springs, lowered 40 mm in the rear using Hagon rear shocks for an EN500, Dyna-S ignition, Dyna coils and plug wires, relay coil mod, H4 headlight conversion, Emgo tail light and some mini blinkers for a scooter. Still a way to go, ao I´m planning on some rear sets and I have a new engine in the works.
From the right:
Post edited by: OnkelB, at: 2007/09/16 15:22
77 KZ 650 B1, 82 GPz 1100 B2.
- OnkelB
- OnkelB
- fixer5000
- Thank you received: 5
Post edited by: fixer5000, at: 2007/09/16 15:27
1978 kz650b pretty much stock
massachusetts
- steell
And the GSXR suspended 650 waiting on the 1105 motor
- rstnick
- Thank you received: 377
The rear fender was the first to go. Also switched to pods. It came with the Yosh 4 into 1, open pipe and LOUD!
Over the years she's seen many changes; Got a Dyna Ign. Cir Cylcle coils and Clutch. First over bore with 3 angle valve job and porting, Kerker exhaust, Atk fork brace, Derale Oil cooler with braided lines, Drilled discs and braided brake lines, Koni shocks and Magnum progressive fork springs;
Painted Candy Apple Blue with Gold stripe following stock lines:
Added a 1/4 fairing:
Had Shoei hard bags and a backrest/rack for part of a season:
Then installed a Rickman fairing, Clubman bars and lost the hard bags, added a Honda VF500 chin scoop and painted the wheels Gold:
Fairing painted blue:
I put on '04 GSXR600 rear sets both sides:
I will be adding a stock length braced swingarm this Winter, as well as trying the electronic Ignition route again (kawi) as I'm using points at the moment.
I also was given my brother's '79 C3, but it sat out in the elements for many years, and probably will not ride again.
Although you can never say for sure. :whistle:
Post edited by: rstnick, at: 2007/09/16 15:56
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- kzwolfsr
- Thank you received: 16
Original man of the Caribbean
- The Gringo
- ¡Usted no necesita otra motocicleta!
- Thank you received: 11
Post edited by: The Gringo, at: 2007/09/16 17:44
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
KZ 550 times 2 80 440LTD-Sold
- The Gringo
Andy
Akron, Ohio
80 Z-1 Classic-Sold
84 GPZ1100
79 KZ 1000 LTD
78 KZ 1000 A2
77 KZ 1000 LTD-Sold
- z1rick
Anaheim CA
1999 KZ 100P
1974 Z1 900 Project
1977 (2) KZ 650 projects
- RonKZ650
- Thank you received: 240
