new to me 1978 KZ 1000
- Treetall
Re: new to me 1978 KZ 1000
28 Jul 2025 09:45
Thanks Wookie
I will check the voltage shortly. The battery is a week old.
The R/R is a used one. There must be a way to test it! I know Ed has said he has purchased several?!
Can you refresh my memory what is FSM ?
I forgot to ask in the first post. What size wires should I be running from the R/R to the battery? I think I'm running a 14 or 16 gauge. Too small!?
28 Jul 2025 09:49 - 28 Jul 2025 09:49
FSM = Factory Service Manual ( not Haynes, Clymer, et cetera)
Last edit: 28 Jul 2025 09:49 by TexasKZ.
- Treetall
28 Jul 2025 10:45Thanks Wookie
The R/R is a used one. There must be a way to test it! I know Ed has said he has purchased several?! If the stator checks out in spec and the voltage readings from the battery and ground are good, the battery is good then that is your R/R test
Can you refresh my memory what is FSM ? Factory service manual
I forgot to ask in the first post. What size wires should I be running from the R/R to the battery? I think I'm running a 14 or 16 gauge. Too small!? 16 is definitely too small, 14 is marginal, I would use 12awg (see below for voltage drops for each size of cable)
The following user(s) said Thank You: Treetall
- Injected
29 Jul 2025 15:22
I have installed two of those SH775 RR's on my bikes, I run #10AWG wire direct to the battery. On the positive side I run a 30A inline fuse between RR and battery.
1978 KZ650B2 modified project
- Treetall
29 Jul 2025 20:55 - 29 Jul 2025 21:03What is the battery voltage when the motor is "off" ? I charged the battery yesterday. Today it is/was at 13.1 volts before doing tests.I have an electrical question.
I installed a SH 775 R/R. It's the proper one, with the stamp on the fin.
First I had the positive going into the OEM plug with the fuse. But I wasn't getting enough volts. So I hooked it up directly to the Battery. Positive and negative.
All the connections are solders. I hooked the stator wires ( Yellow, Blue, Red) to the R/R. Eliminating the old plugs, wires, and regulator, rectifier.
Testing all 3 combo's RY, RB, YB. I get 60 VAC @ 4000 rpm. But I can only get 12.62 VDC , at the battery at 4000 rpm.
Is this pointing toward a weak stator? From all the reading I've read on here. It's kinda pointing that way!?
Is the R/R you have "new" or "used" ? The r/r is used
With stator disconnected have you checked the resistance as per the FSM ? (RY,RB,YB should be between 0.56 - 0.84 ohms) With the ohms set on 200. All three read 1.5 ohms each.
Set at 2k they read .002 ohms
also check between each of the three leads and ground. I checked these and got no reading. So this should tell me there is no short! Correct?!
with everything connected put a voltmeter red lead to battery "positive" and black lead to "positive" coming out of the R/R (should be no more than 0.5v)
Connect voltmeter black lead to battery "neg" and red lead to ground wire coming out of R/R (should be no more than 0.3v) I'm not sure if I was doing this right. But I got the same voltage at the battery and at the connection coming out of the R/R, on all the different combos.
I couldn't see a stator spec in the manual but I believe anything above 50v AC on each leg is OK I checked it again and was getting 67 VAC on all 3 wire combos.
I checked the voltage at the battery after letting it idle for a few minutes to warm it up. 1500 RPM- 12.73V 2000 rpm - 12.80V 4000 rpm-12.92V
I also switched up to a 12 AWG pos. and neg. wire off the R/R to Batt.
Last edit: 29 Jul 2025 21:03 by Treetall.
- Treetall
29 Jul 2025 21:00I have installed two of those SH775 RR's on my bikes, I run #10AWG wire direct to the battery. On the positive side I run a 30A inline fuse between RR and battery.
Thanks Injected
I went with a 12 Gauge wire. On the Pos. and Neg. Automotive store didn't have any #10. Good point on the inline fuse, I plan to do the same.
- Treetall
08 Aug 2025 20:29What is the battery voltage when the motor is "off" ?I have an electrical question.
With stator disconnected have you checked the resistance as per the FSM ? (RY,RB,YB should be between 0.56 - 0.84 ohms) also check between each of the three leads and ground
I charged the Battery over night. It was a t 13.1V before the tests.
The R/R is used.
So this is way different than the FSM!
I'm not much of an electrical guy. But the ohms would indicate a high resistance at 1.5ohms or low at .002 ohms!
So if I'm getting 67VAC coming off the stator but only 12.92 @ 4000. would that indicate a snafud R/R?
Or are the ohms telling me the stator is fubarred?
Thanks
10 Aug 2025 01:36 - 10 Aug 2025 04:08I think you are getting in a muddle with your resistance readingsSet at 2k they read .002 ohmsWith the ohms set on 200. All three read 1.5 ohms each.
I checked these and got no reading. So this should tell me there is no short! Correct?! - Correct
200 ohm scale 1.5ohms - on a 2K scale this would read 0.0015Kohms. Your reading of 0.002Kohms on a 2K scale (the meter only has 3 segments so 0.0015 will become 0.002) On the 2K scale you are measuring Kohms (kilo-ohms)
Either way this is significantly higher than spec below which would suggest the stator is at the end of it's life
Last edit: 10 Aug 2025 04:08 by Wookie58.
- Treetall
20 Aug 2025 21:42I think you are getting in a muddle with your resistance readingsSet at 2k they read .002 ohmsWith the ohms set on 200. All three read 1.5 ohms each.
Thanks Wookie
I was away for a couple weeks.
What is it that “ bites the dust”?
Any suggestions on where to get a stator?
I read somewhere that” Ricks forget the last part” is a good source!?
20 Aug 2025 23:09
Ricks Motorsport seem to have a pretty good reputation, I can't advise you where to go for a replacement. Sorry
The following user(s) said Thank You: Formula264
- Treetall
21 Aug 2025 21:56Ricks Motorsport seem to have a pretty good reputation, I can't advise you where to go for a replacement. Sorry
Totally understood!
