new to me 1978 KZ 1000
  • Treetall
  • Treetall's Avatar Topic Author
Re: new to me 1978 KZ 1000
23 Feb 2025 08:02
#909316
I think the Plug wire is ok. I pulled the plug and laid it on the engine. Good spark.
i also swapped plug wires from 2 to 3 and 3 to 2.  Number 2 is still dead.
  • hardrockminer
  • hardrockminer's Avatar
23 Feb 2025 09:24
#909317
If the plug is dry your problem is fuel.  If it's wet then it's something else.  If it's fuel it will be in the choke circuit or the pilot circuit.  If you have fuel screws look inside the hole to see if a PO broke off the tip of a fuel screw.  If you followed the correct procedure to check compression and only got 100 lbs I would consider that to be a poor result, but still enough to have the cylinder fire.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
23 Feb 2025 10:12
#909320
Have you checked all vacum caps are in place, a significant air leak will give the same symptom as no fuel (carbs rely on the depression in the manifold to suck fuel from the jets and an air leak will prevent that depression from occurring) if you remove the pod on the bad cylinder and spray carb cleaner into the intake with the engine running does that cylinder "cut in"
  • TexasKZ
  • TexasKZ's Avatar
23 Feb 2025 13:30
#909328
I once neglected to reconnect the vacuum line to the petcock. Hard to start and ran like poop. Seems that the Rex prefers to have all four firing. Who knew?
  • Treetall
23 Feb 2025 21:59
#909335
Hey Guys thanks for getting back.
I did check the timing after I installed the Dynatek Ignition. It is spot on.
I did pull the plug and it was dry. I looked it up again, and ya 100 lbs is pretty crappy! Not sure where I thought that was good.
I’ll have to borrow a compression tester. All 4 holes were right around 100 lbs. So it may be a POS!
I forgot to mention in the first post, that I replaced the carb holders and all the vacuum caps.
The petcock was replaced with a regular petcock, non vacuum type, and I capped those as well.
I’ll try some carb cleaner, to see if it will fire.
I’m quite sure it’s a fuel problem, I guess I was really hoping that I didn’t have to pull the carbs again.
The bike starts and runs really nice, just only on 3 cylinders.
  • hardrockminer
24 Feb 2025 03:53
#909342
When you capped the petcock vacuum hose did you mistakenly cap the bowl vents?
  • Treetall
24 Feb 2025 21:02
#909362
Umm. I will definitely look into that! Thanks
Without looking. I believe there is 3 short pipes that I put new caps on. One of the carbs didn't have one. I want to say it is #1 or #4
  • Treetall
25 Feb 2025 17:00
#909398
Hey Hardrock
Looks like I did cap the vents. I just found a pic that Patton put on here, 12+ years ago.
 I haven't tried it yet.
I have vent tubes on Cyl.2,3 and 4. # 1 is blanked off. . But how is it that cyl. 3+ 4 are firing with the vents capped? Or # 1, because 1to2 and 3to 4 have the cross tube !
I will uncap them all tomorrow and see what we get!
I should probably have something on those tubes to keep the dirt and rain out!?
  • Treetall
25 Feb 2025 17:14
#909400
I went back and read the thread from 2012. I think all my questions were/ are answered in the thread.
I will give it a shot tomorrow. Fingers crossed!
  • Treetall
27 Feb 2025 10:49
#909469
Well it appears I've hit another road block.
I pulled the caps off the carb vents between 1 and 2, 3 and 4. I left the cap on #3 as its the vacuum for the old petcock.
But still no fire. I pulled the plug, It appears to be wet and smells like gas.
Not sure where to go from here?
How is it that cyl 1, 3, and 4 are firing/ running when the vents were capped? I shouldn't have an air leak. I replaced the carb holders.
I have the pilot screws set at 2 turns out. Could this be too rich?
Thoughts!?
Thanks!
  • gd4now
  • gd4now's Avatar
  • Denco where did you go?
27 Feb 2025 11:16
#909471
As to vents and vacuum ports on the vm 26 or 28 they work like this.
Keep in mind that some sets so not have the accel pump and some have 2 fuel inlets instead of one. Some do not have the vacuum  port on #3
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
27 Feb 2025 12:02
#909472
Do the carb mounts have fittings for syncing ? are they capped ?
