1973 Z1 rebuild
  • blackozvet
  • blackozvet's Avatar Topic Author
Re: 1973 Z1 rebuild
16 Oct 2022 03:02
#875570
Some things that you do change the look of the bike quite dramatically.
I had to plug the front of the wiring loom into the headlight so that I could start arranging the loom in the frame and begin plugging everything in where it needs to be plugged in.  The added complexity for me (apart from a disinterest in doing wiring ) is the retrofitting of indicators, horn and starter motor.
Anyway the headlight is on and the bike suddenly kinda starts looking like a bike again.
1973 Z1 900 Kawasaki
The following user(s) said Thank You: Nessism, Wookie58
  • blackozvet
Re: 1973 Z1 rebuild
17 Oct 2022 02:50
#875618
I finished hooking up pretty much all the wiring and the ignition housing and Dyna ignition.
Had to dig and dig to find the plate and advance assembly, I had put it somewhere where I wouldnt lose it.
The engine isnt anywhere near starting but time to check the electrics so far before the wiring is tidied up and tucked away.
Its the moment of truth. - hook up the battery and lets see what happens !
Key on, Ignition light on.
Lights work.
Indicators work
Starter motor works.
No neutral light - checked switch, tried old switch, checked wiring, will need to check bulb next.
No Horn - moved switch block and started working.  Next time I tried no go.  Maybe not earthing due to handlebar clamps being powdercoated ?
(442) Kawasaki z1 power on check electrics - YouTube
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1973 Z1 rebuild
17 Oct 2022 04:16 - 17 Oct 2022 04:16
#875619
Lights work.
Indicators work
No neutral light - checked switch, tried old switch, checked wiring, will need to check bulb next. Disconnect wire from switch, connect voltmeter from disconnected wire to battery negative (battery voltage indicates all ok up to the switch - check engine ground -- No voltage suggests open circuit, poss bulb or connector off somewhere)
No Horn - moved switch block and started working.  Next time I tried no go.  Maybe not earthing due to handlebar clamps being powdercoated ? Agreed
Last edit: 17 Oct 2022 04:16 by Wookie58.
  • blackozvet
Re: 1973 Z1 rebuild
17 Oct 2022 23:49
#875665
the reason for no neutral light is found.
  • blackozvet
Re: 1973 Z1 rebuild
18 Oct 2022 00:09
#875666
After contemplating the wonderful world of wiring its time to bolt stuff back on.
I attached the rear taillight onto the rear mudguard, cleaned up bushes and bolts and fitted the guard and hooked up the wiring.
New sidecover rubbers go on the frame.
I might as well take the opportunity to drop the tail, sidecovers and seat in position for a photo op - before removing them and putting them safely away.
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1973 Z1 rebuild
18 Oct 2022 00:21
#875668
Looking really nice, I hope you are proud of the work you have done
  • blackozvet
Re: 1973 Z1 rebuild
18 Oct 2022 02:07
#875669
Thanks Wookie - I'm pretty happy with things so far.  There are always little problems but thats to be expected.
I saw on one of the Z FB groups someone who's rebuild effort consisted of removing the tank, seat and ducktail over a period of 5 years
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: 1973 Z1 rebuild
18 Oct 2022 02:33
#875671
These things take time
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
Re: 1973 Z1 rebuild
18 Oct 2022 04:44
#875672
blackozvet post=875669
Yup.
Our '72 Z1 basket case project that we completed a few years ago earned the moniker 'The Seven Year _itch' honestly.
Been following blackozvet's build with interest since it's inception.  Great workmanship at a remarkable pace.  Bravo!
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: blackozvet
  • willemZ900
  • willemZ900's Avatar
  • Z1B 4 ever
Re: 1973 Z1 rebuild
19 Oct 2022 02:03
#875700
Last year I retired so I stripped my Z completely and rebuild it with all kind of new parts, O rings, bolts, frame repair etc. I started in November and worked almost every day on the bike,  It took me 4 months to complete the bike and started test riding in April of this year. Yes, these things  take time!
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
Re: 1973 Z1 rebuild
19 Oct 2022 08:47
#875708
We're 2 1/2 months into my 77' KZ 1000 LTD build. We've got a couple of parts left to prep and paint. The quickest we've done a bike in was 3 months. That's with me working on it every day and Paul helping 2 or 3 days a week. The LTD will take a bit longer, it's our first KZ build.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
  • blackozvet
Re: 1973 Z1 rebuild
20 Oct 2022 00:18 - 23 Oct 2022 05:25
#875745
Got a box of bits from Z1 Spares, a new instrument light loom, set of plugs, short throttle cables, kickstart rubber and a crankcase breather.
Hopefully this is the last purchase for the bike, apart from any unforeseen circumstances - of which I am quite sure will happen !
So I install the new light loom, switch on ignition and yes I have a neutral light.  But wait - there is now no oil light
So I check the 3 other lights, all working.  Switch the high beam bulb around and now there is an oil light.  Looks like one of the new bulbs that came with the loom is dodgy.
Still no horn, despite filing off the powdercoat on handlebar surface of the upper clamps - maybe I need to get rid of the coating on the main triple tree clamp too?
Is there a good cheap and cheerful way to run an earth off the button?
Last edit: 23 Oct 2022 05:25 by Street Fighter LTD.
