1973 Z1 Maui
- MauiZ1
Re: 1973 Z1 Maui
19 Oct 2021 08:11
Each of the shafts has two nylon pieces, one inside and one outside.
- slmjim+Z1BEBE
Re: 1973 Z1 Maui
19 Oct 2021 08:16
This is slmjim.
That looks maddeningly familiar.
Is the ID the same as the long shaft (16041-004), #83 in the parts manual? Does the OD match the bore where the shaft passes through the carb holder (16065-019) #88 in the parts manual? Hard plastic or stiff-ish rubber (be gentle! It's old.)?
The only ribless carbs we have are installed & running on our 'The Seven Year _itch' early '72 Z1. When I went through them after stumbling across them at Mid-Ohio, I noticed differences in the small parts on the shaft assy. that didn't precisely match the parts manual, a standalone parts sheet from an old OEM Z1 carb kit or, John's book. I took pics during disassembly for use during reassembly. I may still have them. It'll be later today before I can look & will post tomorrow if located.
Good Ridin'
slmjim & Z1BEBE
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- Online
Re: 1973 Z1 Maui
19 Oct 2021 12:31
I checked with my buddy Kevin today and he said felt is the correct seal. He thinks the felts may have been replaced. He has felts on his restoration of 1006.
- MauiZ1
Re: 1973 Z1 Maui
19 Oct 2021 14:55
It fits nicely on the rack shaft. My parts manual doesn’t really show a part like this. Weird, I went through the rack and carbs and could not see anything missing. The carbs have been run too!
my carbs did not have felts either.
- MauiZ1
Re: 1973 Z1 Maui
19 Oct 2021 15:01
I was going through some photos to check out some “as found” conditions and it’s a wonder I took this bike on, it was pretty ugly, as I imagine many here have encountered.
- MauiZ1
Re: 1973 Z1 Maui
21 Oct 2021 20:20
Working on my master cylinder and I’d like to verify the assembly order and orientation. Does this look correct?
the manual and parts manual are a little vague.
thank you
thank you
Re: 1973 Z1 Maui
21 Oct 2021 20:56
- MauiZ1
Re: 1973 Z1 Maui
22 Oct 2021 07:52
Thank you, I was wondering if I was seeing the manuals wrong. The illustrations aren't very good.
The FSM skips over a lot of details.
- slmjim+Z1BEBE
Re: 1973 Z1 Maui
24 Oct 2021 08:08Sorry it took this long. The prints were buried in a manual we haven't had out for over two years. The pics were taken for our reference only & printed low-res on a B&W printer without ever planning to be made public.This is slmjim.
Good Ridin'
slmjim & Z1BEBE
In the parts manual we see #76 'COLLAR D' next to the long spring #75. Below that is the carb rack itself, #88, and also #84 'COLLAR F'. There is no collar shown between the rack's left boss bore and #76 'COLLAR D'. We believe the mystery collar is located between (inside) the boss and 'COLLAR D'. Without disassembling the rack that's on our bike now, that's as close as we can come to recommending where the mystery collar belongs. See pic below.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
- gd4now
- Denco where did you go?
Re: 1973 Z1 Maui
24 Oct 2021 13:03
I do not know that this will be of any help but that part sort of looks like #66 in this pic from a Z1 manual?
1977 KZ650 B1
Pods and Denco header
OLD KAW OWNERS SMILE ALOT
The following user(s) said Thank You: slmjim+Z1BEBE
- MauiZ1
Re: 1973 Z1 Maui
25 Oct 2021 08:34
SlimJim
That looks like it, I'll take the rack apart and check.
I checked the carbs, they are ok.
As I wait for chrome and other things I'm going through sub assemblies. Amazing how many little parts were missing on this bike. As an example, the small bushing in the clutch lever pivot was not there, instead of the bushing and a 5mm bolt it was just a 6 mm bolt.
The endless stream of small parts continues.
- slmjim+Z1BEBE
Re: 1973 Z1 Maui
25 Oct 2021 09:07 - 25 Oct 2021 09:10Indeed that does look similar! Thanks for the suggestion.
We don't have any loose carbs at the moment we can disassemble to check.
MauiZ1, gd4now's suggestion might keep you from having to deal with those aggravating #*^& ! return springs.
Good Ridin'
slmjim & Z1BEBE
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
USA
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 25 Oct 2021 09:10 by slmjim+Z1BEBE.
