1977 KZ1000 Restomod
  • Skidmark
  • Skidmark's Avatar
Re: 1977 KZ1000 Restomod
05 Dec 2022 07:44
#877522
That's a real purdy weld on that switch mount, calum!
Retired gearhead
'81 KZ-750 E2
  • calum
  • calum's Avatar Topic Author
05 Dec 2022 09:42
#877528
Thanks :) TIG welding steel is probably the easiest type of welding though...
  • Skidmark
  • Skidmark's Avatar
06 Dec 2022 08:50
#877573
I can MIG weld okay... but TIG requires three limbs at the same time.  I am lucky if I can walk and chew gum at the same time!  I never have taken the time to learn TIG welding.
Retired gearhead
'81 KZ-750 E2
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
06 Dec 2022 09:04
#877574
I would like to learn but again it's a significant investment in more equipment
  • calum
07 Dec 2022 06:56
#877582
That's true, but I didn't have anything over here so just went straight for a TIG setup with hopes of welding aluminium... Still working on that
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
07 Dec 2022 11:19
#877588
I've had my Mig for around 25 years so maybe when my wallet has recovered from this build it's something to look at
  • calum
07 Dec 2022 13:42
#877593
Worth the investment - just make sure you get a decent foot pedal, mine's pretty crappy and makes welding aluminium a lot harder than it should be.
  • Wheelhop
  • Wheelhop's Avatar
07 Dec 2022 16:50
#877596
Could you find a replacement pedal (reasonably priced) or with your talent -fix or fabricate a new one?
1978 KZ 1000B (73 tribute)
1977 KZ1000 project
1976 KZ 900
1976 KV 75
1976 Honda Elsinore MT250
1974 Z1 900 project
1971 Honda CT70
2000 ZRX 1100
  • Skidmark
  • Skidmark's Avatar
09 Dec 2022 08:49
#877663
When it comes to welding aluminum, you cannot get the substrate clean enough.  Clean the bejesus out all surfaces, and clean your filler rods as well.  Once you get everything clean, clean it all again.  After certifying four of my welders for aerospace welding this was one of the most important things I gleaned from the process.  Yes, I know the process well, I just can't do it myself.  My shop was welding on Patriot missile parts for Raytheon back in my working days.  Man, that took a ton of paperwork and physical testing of weld samples.
Retired gearhead
'81 KZ-750 E2
  • calum
20 Dec 2022 17:54
#878043
Bit late replying...
I could get a decent pedal but would need to rewire it. Not that hard but I have been putting it off. I have a torch with a dial to control the amps and have been meaning to see if I can get used to controlling things that way.
I guess I'll have to sit down for a weekend with a pile of aluminium and see how I go.
Going to try and get the other build running by the end of January and then I'll get back to this one.
  • blackozvet
  • blackozvet's Avatar
20 Dec 2022 17:59
#878044
funny how you have to go to so much trouble welding a missile just so it can get blown to smithereens !
1973 Z1 900 Kawasaki
  • Skidmark
  • Skidmark's Avatar
21 Dec 2022 07:48
#878072
The military has a funny reaction to weld failures before their missiles hit what they want them to.  Since it makes them not hit what they wanted them to.
Retired gearhead
'81 KZ-750 E2
