- Thank you received: 312
KZ750H Restoration
- Skidmark
Retired gearhead
'81 KZ-750 E2
- Thank you received: 1852
- calum
- Thank you received: 415
Got the front seat on as well. Even looks pretty tidy under the seat
KZ1000 Restomod ( www.kzrider.com/forum/11-projects/614517-1977-kz1000-restomod )
2000 BMW F650GS
- calum
I've found a couple of other things to obsess over in the meantime
2000 BMW F650GS
- calum
Ended up getting the soldering iron out to detach the two wires so I could slip some heat shrink over them - not resorting to insulation tape yet!
All back together minus the plate holding the lighting wires in place as it doesn't seem to fit right on the new housing. The housing is from a German model without the reserve lighting device so two less wires running to the hi/lo beam switch. Will still be OK, just have to be a bit more careful when putting them on.
2000 BMW F650GS
- riturbo
- Thank you received: 342
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
- calum
Problem is, the negative lead had broken off when I got the bike so I'm not sure whether it ever worked. Any ideas?
2000 BMW F650GS
- loudhvx
- Thank you received: 1622
It's most likely a thermistor.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- calum
2000 BMW F650GS
- loudhvx
I'm looking at an 82 Kz750H2 diagram...
This diagram shows a green wire, but I think it might actually be a green/white wire.
One test you can do is to ground the green or green/white wire that goes to the sensor. The light should then go on.
If it does, then you prob have to get a new sensor.
You might be able to swap in a generic car thermistor if you think you can solder a new one in place. The one on my old car was a small "tank" just soldered to the stalk. The tank had a wire coming out. That would go to your green/white wire. The "stalk" is ground and is what the ground wire would go to.
They come in different resistance values and I couldn't find it in the cheap third party manual I have for 750's. But they usually come available in ranges like 50 ohms, or 100 ohms, or 1000 (1K) ohms. I guess I would try a 100 or 50.
When the fuel drops below the sensor, a small current through the bulb slowly heats the sensor and drops its resistance, which then allows more current and the light bulb to light up.
Be aware, this is mostly speculation on my part. So if someone more specific info, I would go with that.
Amazing resto, by the way!
1981 KZ550 D1 gpz.
Other links.
- calum
loudhvx wrote: When the fuel drops below the sensor, a small current through the bulb slowly heats the sensor and drops its resistance, which then allows more current and the light bulb to light up.
Ahhh... that's my problem - I'm checking for continuity but there is no power to the sensor. I figured if it was disconnected the circuit would be closed if it's not submersed - a result of not understanding what is going on
loudhvx wrote: Amazing resto, by the way!
Thanks
2000 BMW F650GS
