KZ650 cafe-racer
  • gazzz
  • gazzz's Avatar Topic Author
Re: KZ650 cafe-racer
04 Apr 2022 13:44
#864903
When assembled it looks like this:
Sandpaper could be installed on any side of the disc or on both sides simultaneously.
Kawasaki KZ650 cafe-racer: in progress
Kawasaki Zephyr 750 (810ccm, 4in4, spoked wheels)
Honda CB815 "Eight Fifteen" cafe-racer
Yamaha XJ "Eight Ball" cafe-racer
www.gazzz-garage.com
  • gazzz
04 Apr 2022 13:46
#864904
And last but not least attachment for rotary tools. Actually it's the most useful tool especially when it comes  treating pipes or holes from inside (including ports of cylinder head). But it could be used on outer surfaces, ribs and grooves as well.
Most of "universal" sets of accessories for rotary tools come with pretty useless drill bits. Usually they might be used on wood or plastic but they are no good for metal.
We need two things  to turn these drill bits into useful attachments. First is a rectangle of sandpaper (cut from sheet or roll).
  • gazzz
04 Apr 2022 13:47 - 04 Apr 2022 13:47
#864906
Diameter and length of future depend on dimensions of sandpaper rectangle.  It has to be rolled in tube like this:
Last edit: 04 Apr 2022 13:47 by gazzz.
  • gazzz
04 Apr 2022 13:48
#864907
Roll of sandpaper has to have an internal diameter suitable for the drill bit, so the drill bit may be screwed into the roll with little force. Second thing we need for the tool is a strip of paper tape or vinyl tape or duct tape.  With the help of that strip we have to fix sandpaper to drill. Mind direction of rotation.
  • gazzz
04 Apr 2022 13:49
#864908
This tool doesn't like side loads because it essentially is paper. But it could last for quite a long time, since after the upper layer is worn it may be torn off exposing a new layer of fresh sandpaper and so on and so forth until the end of layers. Same thing with the working end of the tool: once it wears, it may be cut off with scissors.  Wide range of sandpaper grit make this tool truly universal. Here are some examples of worn or half worn sandpaper attachments I have used some time ago:
The following user(s) said Thank You: linuxrob
  • gazzz
04 Apr 2022 13:50
#864909
And here is the most illustrative example of work I did using all four types of tools. I believe you have already seen it.
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
04 Apr 2022 14:19
#864911
Its like a piece of art.
The following user(s) said Thank You: gazzz
  • Forrest
  • Forrest's Avatar
  • The Mad Duck
04 Apr 2022 15:47
#864916
Absolutely beautiful work.
  • TexasKZ
  • TexasKZ's Avatar
04 Apr 2022 19:08
#864923
Thank you for sharing your custom tools. I may never rival your skill, but these tools will improve my work considerably.
  • linuxrob
  • linuxrob's Avatar
05 Apr 2022 07:24
#864944
Many many thanks for sharein your methods. I look forward to making a few of these myself.
Our thoughts are with you all
Rob B
UK
1980 Z500 B2 owned from new 78260 miles
1980 Z500 B2 in bits since 1982 23000 miles
2004 GSF1200S Bandit K4
2000 GS125 ESD
  • gazzz
06 Apr 2022 02:18
#865026
Well,  that was a rather simple decision: knowledge is better to be shared than to be lost.
With the emergence of pictures of massacre in north Kyiv suburbs (Bucha, Irpin) and nearby towns like Borodyanka I feel a black rage I have never felt before. Those atrocities made by Russians, they should never have happened in 21th century.
The following user(s) said Thank You: kzstreetfighter71, Scirocco, Wookie58
  • gazzz
06 Apr 2022 02:27
#865027
However, here's another little thing I kept forgetting to do. I found the original part list of the 1983 Kawasaki KZ750 (L3)  on the  Internet some 15 years ago. Since then I managed to forget I found them until one day I was sorting all manuals and lists in my PC. The list is in pictures (JPS, 300dpi), so I ZIPed them in one archive.  I loaded scans  to my Google Drive and shared them.
Here is a link:
drive.google.com/file/d/1XR9Z3YPX-ES2fjv...gT2/view?usp=sharing
