Wakt out KZ1000
  • waktaylor
  • waktaylor's Avatar Topic Author
Wakt out KZ1000
25 Sep 2018 20:18
#791422
Here's what I'm starting with: 1978 KZ1000
with cash and some love it will be as cool as Bob's z1. Im pretty much gonna copy his. Cause that's cool.
Can't wait to get started. From what I read frame bracing is key. Im debating dropping the coin ($640) for BS34s from George. I think it will be worth the dough, but I'm not even sure of this bike's condition. I can spin it with the kick start, but nothing is in ready to run status.
Im pulling the carbs in a day or two to clean them up, and reinstall. Tank is very clean inside, even though the bike sat 4 years. Hoping they drained the carbs too.
Since the fork is all wadded up I've been looking into stealth upgrades, such as the 90s zx11 front end and brakes. I want to keep spoke wheels to keep with the era.. the era before mushrooms were replaced with stupid aluminum mags. I guess too much cocaine in the 80s brought mag wheels and square sealed beams into our darker history. Spoke wheels just look better on these to me.
Anyone have a measurement of the space between the dual rotor setup?
8
[IMG
2
[IMG
3
[IMG
3
[IMG
6
[IMG
1
[IMG
-Wakt
  • TexasKZ
  • TexasKZ's Avatar
Re: Wakt out KZ1000
26 Sep 2018 06:31
#791434
Why do you want to ditch the stock carbs for BS 34s? Seems like an expensive way to gain a lot of headaches to me.
  • TexasKZ
  • TexasKZ's Avatar
Re: Wakt out KZ1000
26 Sep 2018 06:33
#791435
Also, the Ninja forks tend to be pretty short. I think the 636 front end is the longest of the bunch.
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wakt out KZ1000
26 Sep 2018 06:45
#791438
Jon (KAW-A-HOLIC) high sided because of the short forks. Now he's done riding for good. :(
  • waktaylor
Re: Wakt out KZ1000
27 Sep 2018 17:59
#791526
Thanks for chiming in. Decided against the ninja fork.
Old turd is missing a few parts and removing some is proving to be annoying too.
Someone robbed the ignition lobe. there are Dyna 2000 coils installed, and old points, but no lobe.
I was tryin to remove the several extra front foot pegs, but they are mounted by the lower engine bolts. HOW IN THE WORLD do I get those off? The nut on the back side is visible, but no way to get a regular wrench for counter hold.
Pinesol carb clean... they are turning out pretty nice.
[IMG
I removed bag mounts, and there is this extra tab on each side of the frame. Do they all have this?
[IMG
[IMG
  • hardrockminer
  • hardrockminer's Avatar
Re: Wakt out KZ1000
27 Sep 2018 21:07
#791528
Those tabs are on all KZ1000's. I have them on my 1980 LTD.
Are those carbs 26 mm or 28 mm?
  • ayeckley
  • ayeckley's Avatar
Re: Wakt out KZ1000
28 Sep 2018 02:41
#791529
waktaylor wrote: I removed bag mounts, and there is this extra tab on each side of the frame. Do they all have this?
I think you are referring to the rear turn signal mounts. I don’t recommend it, but if you decided to cut them off and can do it reasonably non-destructively I’m in the market for a pair.
1976 KZ900A4
1976 KZ900A4
1978 KZ1000A2
1983 ZX750 A1 aka GPz 750
1983 ZX750 A1
1973 CL350K4
1984 ZX1100 A2 aka GPz1100
1969 CT90
2006 Burgman 400
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Wakt out KZ1000
28 Sep 2018 07:07
#791533
I think they are for helmet hooks.
  • waktaylor
Re: Wakt out KZ1000
28 Sep 2018 18:30 - 29 Sep 2018 10:08
#791565
Did some thorough grime removal today.
Also found that the PO had replaced the lower engine mount bolts with smaller ones. I guess the stock nut is large enough to hold itself. All good cordless impact got it out.
Carbs are headed to WiredGeorge. #2 is stuck and #3 is sticky.
Ordered Dyna 2000 and plug wires since the PO removed the advancer and ignition lobe.
Removed rusty battery tray. Will do something with that. Im gonna need the 9" rear engine bolt and spacers soon. PO took it out for whatever reason.
[IMG
[IMG
[IMG
[IMG
Last edit: 29 Sep 2018 10:08 by waktaylor.
  • waktaylor
  • bluej58
  • bluej58's Avatar
Re: Wakt out KZ1000
30 Sep 2018 06:09 - 30 Sep 2018 06:09
#791603
It's a good idea to squirt some penetrating oil on all the nuts and bolts and give them a few light taps with a hammer in advance of removing them.
I used an epoxy paint on my battery box and it is holding up great, Z1E sells the rubber bumpers that go in the box
78 KZ1000 A2A
Last edit: 30 Sep 2018 06:09 by bluej58.
The following user(s) said Thank You: waktaylor
  • waktaylor
Re: Wakt out KZ1000
30 Sep 2018 08:06
#791607
Surprisingly most everything is coming off easy. The lower engine bolts were the wrong ones since PO used a regualr nut instead of the tear drop ones. I made me a nice order from Z1 yesterday. Im about to pull the trigger on swingarm brakes wheels and fork.
