1982 Gpz 750 R1
  • GPzMOD750
  • GPzMOD750's Avatar
Re: 1982 Gpz 750 R1
06 Mar 2016 08:58
#714121
tri650 wrote: Thanks for the inspiration and model advice. Your bike sounds great. Hope to be on the road by next weekend - weather permitting.
I just dropped the pan and the cheap gasket was torn in the corner where it was leaking. Lesson learned.
You're welcome. There is one part that I have not been able to find to be interchangeable, the seat. I even tried ordering a GT750 seat pan from the UK. It's not a direct fit and I could probably make it work. Luckily, I found a seat on ebay that wasn't too expensive. The cover and foam were completely trashed but It's the pan that's important so I jumped on it before anyone else could. I plan on making a solo seat out of it and using the spare space for a tail rack so I can carry my lunch to work. Later on I will put a Cafe-ish type tail cowling on it.
My point is if you can get a spare seat or just seat pan for less than $100 jump on it even if you don't see a use for it right away.
  • GKBO
  • GKBO's Avatar
  • Saving old"dead" bikes
Re: 1982 Gpz 750 R1
06 Mar 2016 08:59
#714122
Sweet looking ride all dressed up!Looks like a Corbin seat?
  • tri650
  • tri650's Avatar Topic Author
Re: 1982 Gpz 750 R1
06 Mar 2016 09:37
#714129
Never thought of a Corbin. Don't like the red/black plus it is not in very good shape. Looking for a stock seat cover.
  • GPzMOD750
Re: 1982 Gpz 750 R1
06 Mar 2016 09:46
#714130
tri650 wrote: Never thought of a Corbin. Don't like the red/black plus it is not in very good shape. Looking for a stock seat cover.
This is as close as you are going to get. You are going to have to modify the foam under the one you have.
  • tri650
Re: 1982 Gpz 750 R1
06 Mar 2016 13:58
#714156
Thanks for the tip. Just ordered one. I have done Seat Concepts covers on my dual sport and dirt bikes so have some experience with seat covers.
  • GPzMOD750
Re: 1982 Gpz 750 R1
06 Mar 2016 14:01
#714157
Is your seatpan plastic or fiberglass?
  • tri650
Re: 1982 Gpz 750 R1
06 Mar 2016 14:02
#714159
Looks like plastic
The following user(s) said Thank You: GKBO
  • GPzMOD750
Re: 1982 Gpz 750 R1
06 Mar 2016 14:04
#714160
OK, just wondering. I know Corbin used fiberglass a lot. The factory ones are plastic.
  • GKBO
  • GKBO's Avatar
Re: 1982 Gpz 750 R1
07 Mar 2016 10:15
#714292
Looking again it looks like a modded stock seat that's been cut down and recovered.Going to do one of those Pit Replica covers on mine when I get that far.From everything I've heard they're really good!You're most likely have to add back the foam like GPzMOO750 said.
  • GPzMOD750
Re: 1982 Gpz 750 R1
07 Mar 2016 11:02
#714297
I've been thinking, if anyone needs an original seat pan I'd be willing to work a trade for an aftermarket pan. I'd feel less guilty doing any significant mods if needed.
  • tri650
Re: 1982 Gpz 750 R1
08 Mar 2016 07:37
#714455
Is this correct sequence of parts? I forgot how this went back together. I looked at parts fiche and it showed it this way but that was not the way I had it set up.
Attachment Oilfilter.jpg not found
  • KZB2 650
  • KZB2 650's Avatar
Re: 1982 Gpz 750 R1
08 Mar 2016 07:42
#714457
You got it right Tri650. ;)
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
