1982 Gpz 750 R1
- Shimmy
Re: 1982 Gpz 750 R1
29 Mar 2016 17:07
    I had a problem with running on fewer cylinders when the bike was warmed up, mostly at or near a stop, and in my case the issue was the pickup coils.  The manual should have the method for testing yours; should just take a couple minutes and a multimeter.
      1980 KZ750 LTD
Edmonton, Alberta
  Edmonton, Alberta
- tri650
Re: 1982 Gpz 750 R1
29 Mar 2016 19:07
    I found the tests and also a few youtube video's for testing.  I guess this will be the first line of testing.  I was planning on doing it tonight and started to take the tank off by putting the petcock on Res - and gas kept coming out of the petcock after I took off the line.  I just rebuilt this thing last week.  Guess I will take it off and see what happened.  Seems I take 1 step forward and 1 step back with this bike.  Oh well, I have all summer.
- tri650
Re: 1982 Gpz 750 R1
10 Apr 2016 16:58
    Quick update.  After tearing into the carb, petcock, new plugs, gas cap, etc., I was still running into the bike stumbling and running like crap.  I had gone through everything multiple times.  Ordered new coils and plug wires.  Got rid of the K&L petcock rebuild kit as it was junk and the parts did not fit.  I took it out for a ride on Friday and still got the stumbling and at one point I had the throttle pinned and it would only do 35 mph.  I was about home when it suddenly started to pick up.  I kept going and put on about 30 miles without any problems.  Saturday I put about 70 miles on it.  Slight stumble off of idle which I resolved with another 1/4 turn on the pilot screw.
Took out today and same result - now runs like a scalded cat. I have no idea what magically fixed itself but it is running great. Starts up, holds idle. Now onto the finishing touches.
Still looking for a front fairing.
