Kz650 1978
Re: Kz650 1978
06 Jul 2014 07:53jmoney05 wrote: I don't know why it keeps turning my photos sideways!?!?
I don't know either, but have rotated the side-ways images which you originally posted.
- jmoney05
- jmoney05
- Greasedmonkey
Re: Kz650 1978
09 Jul 2014 19:03
HOly crap! I love this. I wish I had the time and ability to do this to my 650. ITs just about what I want mine to be in the end.
1980 KZ650E
The following user(s) said Thank You: jmoney05
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:30 - 16 Jul 2014 07:57
Ok so I just got a sweet deal on a 2002 Gsxr 600 swingarm which is polished to match the wheels I picked up. Better candidate for my application because it has no top support..
So I spent last night at work making new swingarm pivot bushings so I can use the stock pivot bolt from the kz!
Attachment image_2014-07-16-7.jpg not found
1978 Kz650D
Last edit: 16 Jul 2014 07:57 by jmoney05.
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:32 - 16 Jul 2014 07:33
These bushings I made from 304 stainless, they also act as washers to make a nice snug fit between the kz frame. They also replace the bearing race.
1978 Kz650D
Last edit: 16 Jul 2014 07:33 by jmoney05.
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:36Attachment image_2014-07-16-2.jpg not found
Here is the swingarm which I will be using. It just needs cleaned up.
1978 Kz650D
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:45
Been doing a lot since I've last posted, some amateur body work to fix a dent and rattle can paint job. Had the tank down to bare metal primed sanded primed again then a few coats of pain and clear coats .
Attachment image_2014-07-16-3.jpg not found
Attachment image_2014-07-16-4.jpg not found
Attachment image_2014-07-16-5.jpg not found
1978 Kz650D
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:50
I pulled a nasty dent out by filling the tank with 20psi of air and a small plunger, I then proceeded to fill over with bondo body filler, also while I was at it filled in the areas where kawasaki emblems mount, for nice smooth sides.
1978 Kz650D
- jmoney05
Re: Kz650 1978
16 Jul 2014 07:54
Here is what the dent
looked like.
Attachment image_2014-07-16-6.jpg not found
looked like.
1978 Kz650D
Re: Kz650 1978
17 Jul 2014 06:01 - 17 Jul 2014 06:01jmoney05 wrote: Ok so I just got a sweet deal on a 2002 Gsxr 600 swingarm which is polished to match the wheels I picked up. Better candidate for my application because it has no top support..
nice looking top hat bushings .
are running your bearings directly on the bushings?
Last edit: 17 Jul 2014 06:01 by 531blackbanshee.
- jmoney05
Re: Kz650 1978
17 Jul 2014 07:42
Yes Leon , the bearings that are pressed into the swingarm my bushings ride on the bearings. Replacing the sleeves that were in there.
1978 Kz650D
