Kz650 1978
  • jmoney05
  • jmoney05's Avatar Topic Author
Kz650 1978
10 Sep 2013 22:59
#605926
Been working on my kz, not sure the direction I am going.(cafe/drag).
1978 Kz650D
  • jmoney05
Re: Kz650 1978
10 Sep 2013 23:19
#605930
Here is a part I made to replace the plastic for the choke linkage. Made a total of 8 pieces to hav some extra on the shelf
1978 Kz650D
  • DesertKZ
  • DesertKZ's Avatar
Re: Kz650 1978
11 Sep 2013 14:42
#606019
That's a cool part, had to replace all four of mine last year, the plastic ones just crumbled away. Granted, they were probably 34 years old. :)
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
  • jmoney05
Re: Kz650 1978
11 Sep 2013 23:05
#606101
Thanks, yeah only one of my plastic ones was usable. So I decided to make my own out of some brass I had laying around, hopefully they will hold up better than the plastic ones.
1978 Kz650D
  • jmoney05
Re: Kz650 1978
11 Sep 2013 23:08
#606105
Thinking of trying my luck at making a new rear master cylinder cap,as my original one is cracked.
1978 Kz650D
Re: Kz650 1978
11 Sep 2013 23:20 - 13 Sep 2013 21:26
#606107
If you do, take a real close look at the original. There is a vent in the form of a slot cut through the threads. Ed
Last edit: 13 Sep 2013 21:26 by 650ed.
  • jmoney05
Re: Kz650 1978
15 Sep 2013 22:31
#606612
Ok thanks ,I did not know that.
1978 Kz650D
  • jmoney05
Re: Kz650 1978
22 Oct 2013 10:32
#610802
Attachment image_2013-10-22-7.jpg not found
Attachment image_2013-10-22-8.jpg not found
1978 Kz650D
  • jmoney05
Re: Kz650 1978
22 Oct 2013 10:35
#610804
2006 gsxr1000 front end
Attachment image_2013-10-22-9.jpg not found
1978 Kz650D
  • jmoney05
Re: Kz650 1978
24 Nov 2013 23:03
#614035
Attachment image_2013-11-25.jpg not found
Attachment image_2013-11-25-2.jpg not found
Attachment image_2013-11-25-3.jpg not found
1978 Kz650D
  • jmoney05
Re: Kz650 1978
21 Jan 2014 14:19
#619497
Attachment image_2014-01-21.jpg not found
1978 Kz650D
  • jmoney05
Re: Kz650 1978
21 Jan 2014 14:30
#619501
I wound up using the stock kz stem. The stem was swimming in the triple, but was only .010 difference so .005 per side...bushing would be too thin. So I bored the hole in the triple clamp larger and also turned the stem down leaving about .025 of a lip for the bottom seal, I then made the bushing for the stem. I now plan on making a slug to go inside the bottom of the stem which I will drill and tap after I weld the bushing stem and slug all together. Then press into the triple and use a bolt on the bottom.
1978 Kz650D
