Kz650 1978
- jmoney05
Kz650 1978
10 Sep 2013 22:59
Been working on my kz, not sure the direction I am going.(cafe/drag).
1978 Kz650D
- jmoney05
Re: Kz650 1978
10 Sep 2013 23:19
Here is a part I made to replace the plastic for the choke linkage. Made a total of 8 pieces to hav some extra on the shelf
1978 Kz650D
- DesertKZ
Re: Kz650 1978
11 Sep 2013 14:42
That's a cool part, had to replace all four of mine last year, the plastic ones just crumbled away. Granted, they were probably 34 years old.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- jmoney05
Re: Kz650 1978
11 Sep 2013 23:05
Thanks, yeah only one of my plastic ones was usable. So I decided to make my own out of some brass I had laying around, hopefully they will hold up better than the plastic ones.
1978 Kz650D
- jmoney05
Re: Kz650 1978
11 Sep 2013 23:08
Thinking of trying my luck at making a new rear master cylinder cap,as my original one is cracked.
1978 Kz650D
Re: Kz650 1978
11 Sep 2013 23:20 - 13 Sep 2013 21:26
If you do, take a real close look at the original. There is a vent in the form of a slot cut through the threads. Ed
Last edit: 13 Sep 2013 21:26 by 650ed.
- jmoney05
- jmoney05
Re: Kz650 1978
22 Oct 2013 10:32Attachment image_2013-10-22-7.jpg not found
Attachment image_2013-10-22-8.jpg not found
1978 Kz650D
- jmoney05
Re: Kz650 1978
22 Oct 2013 10:35
2006 gsxr1000 front end
Attachment image_2013-10-22-9.jpg not found
1978 Kz650D
- jmoney05
Re: Kz650 1978
24 Nov 2013 23:03Attachment image_2013-11-25.jpg not found
Attachment image_2013-11-25-2.jpg not found
Attachment image_2013-11-25-3.jpg not found
1978 Kz650D
- jmoney05
- jmoney05
Re: Kz650 1978
21 Jan 2014 14:30
I wound up using the stock kz stem. The stem was swimming in the triple, but was only .010 difference so .005 per side...bushing would be too thin. So I bored the hole in the triple clamp larger and also turned the stem down leaving about .025 of a lip for the bottom seal, I then made the bushing for the stem. I now plan on making a slug to go inside the bottom of the stem which I will drill and tap after I weld the bushing stem and slug all together. Then press into the triple and use a bolt on the bottom.
1978 Kz650D
