KZ 1000 Team Green
  • Bluesmoke69
  • Bluesmoke69's Avatar Topic Author
KZ 1000 Team Green
04 Mar 2013 01:26 - 05 Mar 2013 00:55
#575216
Starting out with a !977 KZ1000 rolling frame. Have all wiring, air boxes, and 3 boxes of other parts. I will need a motor, tank, seat, side cover at some point. not sure what direction I am going to go with this project, I do have a 1997 CBR front end and wheel and all controls. I was going to use on my !976 CB750f, but may use it on this project. The only thing I know for sure is it will cost me more than I want it too, and take twice as long as planed. LOL. An thought on motors or anything else would be great. This is also my first Kawasaki motorcycle.
Last edit: 05 Mar 2013 00:55 by Bluesmoke69.
  • wireman
  • wireman's Avatar
Re: KZ 1000 Something
04 Mar 2013 01:39
#575219
Any 900/1000 motor 73-80 will physically bolt in there B)
  • Zedone
  • Zedone's Avatar
04 Mar 2013 06:49
#575241
You might want to consider a early 2000 ZX6 for your USD front end and monoshock swap. Most of the USD forks are shorter than the stock KZ and cause build issues (ground clearance, also 17" wheels lower the bike,ect) You will need to address tank clearances and swap out trees for starters. There is a board member Les Holt who has a wealth of info on this & many other members have done this mod also.
I like your handlebars :laugh:
Cheers, Doug
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
  • Bluesmoke69
05 Mar 2013 00:54
#575364
Thanks for the information. Is there a preferred motor that is better than others, I know this is going to be a can of worms for some people. :ohmy:
  • wireman
  • wireman's Avatar
05 Mar 2013 01:02 - 05 Mar 2013 01:03
#575365
It all depends on what you want it do do when youre done,how will the bike be ridden? B)
Are you looking for a stock motor to plug/play,or are you looking for a foundation to build off of?
Last edit: 05 Mar 2013 01:03 by wireman.
  • Bluesmoke69
05 Mar 2013 01:28
#575373
Want something that when I am done, I can ride the shit out of it. At some point down the road maybe mild head work, frbut mainly to ride on street. Again thanks for you input.
  • wireman
  • wireman's Avatar
05 Mar 2013 01:38
#575375
If youre just looking for a good solid stock motor Id send a pm to kz1006(brian),hes a member on here with a seemingly endless parts collection! :woohoo:
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: KZ 1000 Team Green
05 Mar 2013 11:13
#575427
the mk11 style case found on 80 z1r's,mk11's use a bigger center pin and have stronger cases.
you can build a beast in any of the 900/1000 cases tho.
hth,
  • Bluesmoke69
06 Mar 2013 00:53
#575574
Thanks for the information guy!
  • 531blackbanshee
  • Vendor
  • Vendor
06 Mar 2013 10:49
#575613
happy to be of assistance sir
  • Bluesmoke69
07 Mar 2013 21:38 - 07 Mar 2013 21:40
#575885
Just a quick look to see what the tank will look like. I have a question anyone ever put a shaft drive tank on a 1977 kz1000 will it fit and if not what mods are need. I guess a better question is what tanks will be a direct swap and which one can be made to fit. Thanks for any help in this matter.
Last edit: 07 Mar 2013 21:40 by Bluesmoke69. Reason: spelling/ no picture
  • wireman
  • wireman's Avatar
07 Mar 2013 21:44
#575886
The 73-78 z1/kz and ltd tanks will fit,79-80 1000 ltd tanks also fit.
Not sure about what it takes for MkII to fit,I think the 79-80 shaft might be its own special fit but not for sure B)
