KZ 1000 Team Green
- Bluesmoke69
Re: KZ 1000 Team Green
01 Dec 2013 16:53 - 01 Dec 2013 17:30Attachment photo_2013-12-01.JPG not found
Got the rest of bike tore down today. Got the terd out and will start cleaning it up and do some inspection on it. Not much will happen until school break in a couple weeks.
Last edit: 01 Dec 2013 17:30 by Bluesmoke69.
- Bluesmoke69
01 Dec 2013 17:31
Not sure whats going on, but my pics. are posting sideways. LOL
02 Dec 2013 06:06
having some nice work space makes getting projects done alot better.
- Bluesmoke69
02 Dec 2013 19:49 - 02 Dec 2013 19:50
Yes it is a great space. Trying to get some Money together to put a garage heater in, it cold in there. LOL
Last edit: 02 Dec 2013 19:50 by Bluesmoke69.
04 Dec 2013 06:25
i get alot of use out of one of the
www.amazon.com/Mr-Heater-Single-Tank-Top...rds=mr+heater+indoor
it is good for heating the "area" you are working in.
it uses the tank off a gas grill(which most folks already have and don't use so much when it's cold)
and is affordable enough until you can spring for climate control.
i have two of them and am glad of it.
- kzz1king
04 Dec 2013 18:04
He is from Minnesota Leon. I would not doubt if he has a sunflower head or 2 around! I call them fish house heaters as most of us have them for our ice fishing shacks. Pretty handy when the power goes out too. What part of OK are you in?
531blackbanshee wrote: i get alot of use out of one of the
Home built KZ1000 turbo setup
- 4TheKZ1000
04 Dec 2013 18:18 - 04 Dec 2013 18:22
Thought I would offer up some help with pics.......rock on.
Attachment photo_2013-12-01.jpg not found
Attachment photo_2013-11-30-3.jpg not found
Attachment photo_2013-11-30-4.jpg not found
Last edit: 04 Dec 2013 18:22 by 4TheKZ1000.
- Bluesmoke69
04 Dec 2013 18:53
Yes i have Some propane heaters, but they stink and are load. It does do the trick in a pinch, but the produce a lot of moister. Thanks for the help with the pictures.
The following user(s) said Thank You: 4TheKZ1000
- kzz1king
05 Dec 2013 19:31
The non vented are terrible for humidity. My propane furnace went on the blink for a bit last year and I used a Mr Buddy to keep it above freezing for a few days. Very humid.
Wayne
Wayne
Bluesmoke69 wrote: Yes i have Some propane heaters, but they stink and are load. It does do the trick in a pinch, but the produce a lot of moister. Thanks for the help with the pictures.
- Bluesmoke69
23 Jan 2014 20:48
Mock up of swing arm using 1998 swing arm spacer and KZ swing arm bolt. The swing arm fit in without dust caps on will have to grind down inside mount about 1/16 on each side. Will also have to cut off mount for the foot peg.
Attachment image_2014-01-23.jpg not found
Attachment image_2014-01-23-2.jpg not found
24 Jan 2014 05:52
a lil closer!!! :evil:
- ZERO
24 Jan 2014 08:54 - 24 Jan 2014 08:58
Nice. Is that a Kawasaki Avenger or Samurai parked in there?
Only Kawasakis have a soul 1977 Kawi KZ1000 special 2000 Kawi ZRX1100
Last edit: 24 Jan 2014 08:58 by ZERO.
