KZ 1000 Team Green
  • Bluesmoke69
  • Bluesmoke69's Avatar Topic Author
Re: KZ 1000 Team Green
07 Mar 2013 22:14
#575893
Thank you wireman!
  • Bluesmoke69
07 Mar 2013 22:26
#575896
I found a parts bike that looks like it was been sitting a while and maybe outside. The bike looks rusty. My question is what do you think of the motor in a 1980 kz1000g Z1 good bad. I will take compression test what is a good reading for a KZ motor. Any thought on value and cost to rebuild thanks Andy.
  • wireman
  • wireman's Avatar
07 Mar 2013 23:58
#575918
That is the fuel injected version of the mkII motor,its a really stout bottem end to build off of.
Big pin crankshaft,extra bracing on cases,tougher trans.........
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
08 Mar 2013 11:35
#575957
pretty sure a shaft drive tank won't fit without mods.
any of the 76-80 900/1000 kz,ltd,z1r,mk11 tanks should fit your frame.
if i am wrong somebody will chime in and correct me.
hth,
  • Bluesmoke69
09 Mar 2013 21:12
#576231
I am sure it is on this site somewhere I did a search, but did not find all information. My question is has anyone done a fuel injection conversion to carbs on the kz1000. I was looking for what parts and the average cost. Is the conversion good or bad any thought or insite would be great thanks Andy.
  • wireman
  • wireman's Avatar
09 Mar 2013 21:23
#576234
Its pretty simple just install the carbs whatever ignition you prefer,assuming of course it doesn't have ignition. :)
  • Bluesmoke69
25 May 2013 22:12 - 25 May 2013 22:13
#589198
Bought this bike today it is in pretty rough shape, but all I needed was the motor, tank and seat.The seat pan is shot. Did compression test today. 122,125,122,125 1-4 cylinders. Sprayed some wd-40 in cylinders be test and kick it over a bunch of time. Thoughts on compression test. Anyone done carb conversion an help or in-site would be great.
Last edit: 25 May 2013 22:13 by Bluesmoke69.
  • Bluesmoke69
25 May 2013 22:48
#589201
What carbs are best for conversion from fuel injected to carbs. I know there are lots that will work,just looking for information thanks Andrew.
  • Matteson
  • Matteson's Avatar
26 May 2013 00:54
#589214
you can get you a set of vm 28's for under 300.
KZ 900-a4
  • Bluesmoke69
26 May 2013 11:28
#589252
I saw in another post that the answer is smooth bore 29mm, what do you guy's think?
  • Matteson
  • Matteson's Avatar
26 May 2013 11:45
#589253
Are you going for a beefy race setup or a daily driver? The 29mm's were an aftermarket setup and will run you well over $700 used. The 28's are a good candidate for a daily driver on a big 1 liter. I rock 26mm's re-jetted for pods and the kerker 4 into 1 on my z900 and can scoot and they aren't too bad on gas. I know, who cares about gas mileage on a hot rod?! But seriously, are you racing that thing? Economically...eh, 28's
KZ 900-a4
  • peavylotus
  • peavylotus's Avatar
  • Movin on up
26 May 2013 15:04
#589275
Did you say your converting that engine to Carburated from Fuel Injection? If so, Im quite interested in why, as well as If your fuel injection set up is complete I will possibly trade you my VM 28 and my cylinder head for your fuel injection set-up and head...Just a thought I figured I would throw out there.
1980 KZ 1045 LTD Currently Workin' It Out
