KZ 1000 Team Green
  • Bluesmoke69
  • Bluesmoke69's Avatar Topic Author
Re: KZ 1000 Team Green
24 Jan 2014 21:15 - 24 Jan 2014 21:17
#619949
Not sure what it is going to morph into yet. LOL IT is killing me, since the move to the new house no heat in garage, and -18 degrees out side. I will be done with school in May so watch out things will be moving then, got new air compressor last month and putting new electrical sub panel in garage. Going to install hanging garage heater, and new welder this summer. Let the good times roll !!!!
Last edit: 24 Jan 2014 21:17 by Bluesmoke69.
  • Bluesmoke69
27 Apr 2014 18:04 - 27 Apr 2014 18:05
#630621
Attachment image_2014-04-27.jpg not found
Attachment image_2014-04-27-2.jpg not found
Did fab work today swing arm. Had to cut rear brake support off. What do you think.
Last edit: 27 Apr 2014 18:05 by Bluesmoke69.
  • Bluesmoke69
27 Apr 2014 18:07
#630622
What do you think of the look and shock angle?
Attachment image_2014-04-27-3.jpg not found
Attachment image_2014-04-27-4.jpg not found
Attachment image_2014-04-27-5.jpg not found
Attachment image_2014-04-27-6.jpg not found
  • Bluesmoke69
27 Apr 2014 20:28
#630641
I like these colors:)
Attachment image_2014-04-27-8.jpg not found
Attachment image_2014-04-27-7.jpg not found
  • Bluesmoke69
27 Apr 2014 20:37
#630642
Also love the color of this bike!
Attachment image_2014-04-27-9.jpg not found
  • Bluesmoke69
18 May 2014 20:05
#632892
Got stems out of KZ and the katana tonight. Will need a space for the katana tree to make the KZ stem work and then weld it in and mock up front end.
Attachment image_2014-05-18-3.jpg not found
Attachment image_2014-05-18.jpg not found
Attachment image_2014-05-18-2.jpg not found
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
19 May 2014 05:38
#632909
can you use the katana stem to machine your bushing from?
i love re-using old stems as material to make bushings for front-end conversions.
  • Bluesmoke69
19 May 2014 15:21
#632994
Yes , if only i had the machine to do the work. LOL :angry:
  • Bluesmoke69
25 May 2014 12:58
#633942
Got this tank yesterday, traded katana frame and motor and payed 35.00 dollars. Tank is pretty nice a couple smal dents but not to bad. Inside of tank need a small amount of cleaning. Pretty excited been looking for a good tank for a while.
Attachment image_2014-05-25-3.jpg not found
Attachment image_2014-05-25.jpg not found
Attachment image_2014-05-25-2.jpg not found
  • Bluesmoke69
08 Jun 2014 20:49
#635864
Got a graduation gift from a buddy today!
Attachment image_2014-06-08.jpg not found
  • Bluesmoke69
08 Jun 2014 20:51
#635865
Got air compressor hooked up, now to find some time to work on the KZ.
Attachment image_2014-06-08-5.jpg not found
Attachment image_2014-06-08-4.jpg not found
Attachment image_2014-06-08-3.jpg not found
Attachment image_2014-06-08-2.jpg not found
  • Bluesmoke69
23 Jun 2014 19:27
#637768
Build this work bench to work on my motor and other things. Used commercial rubber on top and shelf it is chemical resistant. Time to get to work on the turd!!
Attachment image_2014-06-23.jpg not found
Attachment image_2014-06-23-2.jpg not found
Attachment image_2014-06-23-3.jpg not found
