650 Mod's 78 Fighter Build
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: 650 Mod's 78 Fighter Build
29 Jun 2015 13:57
#678738
  • 650mod
  • 650mod's Avatar Topic Author
29 Jun 2015 16:50
#678766
It's been a painfully long two years since I've heard her purr... And the anticipation is getting to me! I'm hoping within two weeks I'll have it on the road again :) The light at the end of the tunnel is getting brighter!
78 kz 650 custom
Wiseco 720cc big bore
Dynajet stage 3 carb kit with pods
2002 Kawasaki Z750 exhaust
2001 Buell lightning front end
1999 Ninja 600 swingarm with 1999 Ninja 900 rear rim
converted to monoshock rear
Too many goodies to list fully
  • 531blackbanshee
  • Vendor
  • Vendor
30 Jun 2015 06:27
#678822
  • 650mod
30 Jun 2015 09:02
#678836
Exactly Leon! This is the last BIG thing that has to get done, then she gets pieced back together. The hardest part from here is going to be wiring in the dyna and the speedo unit. So close....
78 kz 650 custom
  • 650mod
08 Jul 2015 17:43
#680088
I talked with my one buddy who works at the shop I get my stuff powdercoated at, and he said the frame and miscellaneous bits should be ready for pick up tomorrow or Friday! I'm getting antsy to get the bike back on the road... One... step... closer...
Devin
78 kz 650 custom
  • kaw-a-holic
  • kaw-a-holic's Avatar
08 Jul 2015 18:19
#680094
Excited for you Devin, Don't forget to post some pics of the powder coated goodies when you get them back. You may also have to spend some time reaming hole and cleaning out threads.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • 650mod
09 Jul 2015 03:05
#680125
Thanks Kaw. When I dropped the frame and bits off, I had all the openings and threads taped off, and asked them to put some high temp tape in/on anything that I had taped. My buddy sent pics yesterday to show me what they'd done so far, and she was all prepped and taped off :) i'll do a once over on things for sure, but I should be good in that department. And I will for sure, don't you worry one bit ;) I have a feeling the thing that's going to take the longest after this will be wiring in the Acewell speedo cluster and the dyna ignition. But it should all come together in a few days time :)
78 kz 650 custom
  • 650mod
11 Jul 2015 06:29
#680357
So Christmas came in July. .. I got to pick up the frame and other parts from the powder coating shop yesterday! And I'm super happy with how all the parts turned out! The shop even masked off my steering stem so my bearing races got saved, I think I had the biggest smile on my face ever, and my buddy was really happy with the results as well. Anyways, enough of that, and on to the pictures! Everything came out perfectly, and with a mirror finish! For $400 blasted, primed and baked, i'm not complaining.
78 kz 650 custom
  • davido
  • davido's Avatar
11 Jul 2015 08:06
#680367
Im jealous!
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
  • 650mod
11 Jul 2015 08:31
#680375
How gorgeous is all of that? I'm in the process right now of polishing all of my aluminum, then putting Liquid Glass on it. And then doing the same for my painted stuff. For anyone that hasn't heard of/used this stuff- I HIGHLY recommend you look into it. It's basically a clear coat that can go over paint, polished aluminum, chrome... And it doesn't let any oxidizing occur. This is my first time using it, but I'm already loving what I'm seeing. You can apply multiple coats over paint, and the more you apply, the more the paint colour jumps out (especially with metalflake/pearl coats).
Update on the reassembly will go up as I make progress. My goal for the end of the day is to have it a roller with the engine potentially in.
Devin
78 kz 650 custom
  • 650mod
11 Jul 2015 18:21
#680442
Alright so I got the wheels on and the engine in. Wiring harness is strung. And I'm just about to wire in the new Acewell speedo/tach unit. I have a question though- there's a few wires on the KZ wiring harness that I won't be able to use anymore (brake light fault, and a brown wire that hooks up to the neutral, brake, and high beam light). The question I have is whether or not this will affect anything in the wiring harness once I have the new speedo in. As in- with the new speedo in, and the old wires being "dead ends", will this cause any issues?
78 kz 650 custom
  • 650mod
12 Jul 2015 05:05
#680497
Progress that was made yesterday included this, as well as getting the wiring harness strung/labeling wire ends before I start to cut and splice in the new gauge.
Attachment 20150711_1629481.jpg not found
I'm hoping to have the harness fully installed, the gauge in, and potentially my turn signals spliced in by the end of the day. I might be able to do an electronics shake down (fingers crossed) as well.
78 kz 650 custom
