KZ650 CSR from old to new
  • popssss
  • popssss's Avatar Topic Author
  • Bikes, Babes, Pizza with everything
Re: KZ650 CSR from old to new
16 Dec 2012 22:21
#563308
I'm switching the forks tonite....arghhh.
I got careless when my daughter got antsy to get finished.
love bikes, and anything with a engine/motor, and i love the ride way more than the destination, unless I have a passenger, then that's all that matters.
  • martin_csr
  • martin_csr's Avatar
16 Dec 2012 23:21 - 23 Jan 2013 14:01
#563313
Just noticed - the CSRs are 81-83.
If you want cast alloy wheels, the 750-4 is probably a direct swap. For the rear, the 550Ltd.
Last edit: 23 Jan 2013 14:01 by martin_csr.
  • popssss
16 Dec 2012 23:35
#563316
OK it took abut 20 minutes.
Attachment IMG_0096.jpg not found
now, I have a question. On this piece here below, 1 - Brushed, 2 - polish, 3 - powder flat black.
Attachment IMG_0097.jpg not found
the left side is lightly sanded with 400, the right side is highly polished.
I prefer the brushed, since it's easier to keep up, cause if it scratches, just get a piece of sandpaper.
  • popssss
16 Dec 2012 23:40 - 16 Dec 2012 23:41
#563318
Those 550 wheels would look great
I'll check the title at work, the guy who sold it to mw swore it was a 1980 model, but I know what you mean they were 81s.
Last edit: 16 Dec 2012 23:41 by popssss.
  • martin_csr
17 Dec 2012 11:05 - 23 Jan 2013 13:32
#563356
editing error - reply lost
Last edit: 23 Jan 2013 13:32 by martin_csr.
  • popssss
17 Dec 2012 21:51 - 18 Dec 2012 00:06
#563439
The title says 1981 for sure as we suspected. The forks are stock 650 forks, 36mm. (not 37mm like I posted before)
I thought the biggest factor is the width and diameter of the axle that the wheel came from to determine which it will go on.
Heck, there is a bearing shop here in Omaha that can match almost any inner and outer diameter with about any thickness, I also have a buddy who owns a machine shop who can make any spacer I need too.
I'm basically set for making any wheel fit, as long as the wheel OD and width don't change by much.
Last edit: 18 Dec 2012 00:06 by popssss.
  • martin_csr
18 Dec 2012 20:40 - 23 Jan 2013 13:30
#563579
The forks are probably from a 750-Ltd-4.
Last edit: 23 Jan 2013 13:30 by martin_csr.
  • popssss
18 Dec 2012 21:35
#563587
HMM,,,,after looking at my ebay purchase history, they were from a KZ750.
Now the previous axel fits, and the previous fender fits too.
They are a touch longer overall, and the bottom section of the forks is about 2 inches shorter then the 650 while the upper section of the fork is longer than the 650.
The forks came with two new brake calipers too.
  • martin_csr
19 Dec 2012 12:09 - 23 Jan 2013 00:44
#563668
[image link gone]
Last edit: 23 Jan 2013 00:44 by martin_csr.
  • popssss
19 Dec 2012 20:38
#563743
you never cease to amaze me with your in depth knowledge of these bikes. I sure appreciate it, and I'm sure the forum does too.
  • martin_csr
19 Dec 2012 22:51 - 23 Jan 2013 14:00
#563757
The 650-CSR is about the only model I know much about. And from checking stuff, discovered that it is very similar to the 750-Ltd-4.
Last edit: 23 Jan 2013 14:00 by martin_csr.
  • popssss
28 Dec 2012 01:07
#564943
New parts came in.
All from Dime City Cycles.
Attachment IMG_0103.jpg not found
The Grips
Attachment IMG_0104.jpg not found
Blue Dot 7 inch Headlight
Attachment IMG_0105.jpg not found
Black Headlight Mounts
Attachment IMG_0107.jpg not found
Handlebars, and the other stuff on the list, the headlight bucket, 8ball tire valves, a crankshaft keychain
Attachment IMG_0108.jpg not found
Smoked Turnsignals
