KZ650 CSR from old to new
- popssss
- Bikes, Babes, Pizza with everything
24 Sep 2012 19:10
I've posted my pictures in the "new Member" forum by mistake. I'll repost here and track my project too.
so I got a 1980 KZ650 CSR from a guy at work who just let it sit in his garage after he bought a new chain. He just never put it on, even after new front gear and rear gears.
it was awfully dirty, with wasps nests and rust. I have a big job ahead, but it's also a complete bike.
Rusty Frame
Wheels are OK, but I'm adding dual front brakes instead of the single.
Engine was oily and dirty, but after, half a gallon of Castrol purple super clean, a power sprayer and scrubbing, it looks much better, but I'll do a second run at cleaning it up too.
The side covers were terrible too but I've been polishing them and they're turning out ok.
I have the proper front forks to do dual brakes, and I'll paint the lowers black too, same with the front fender.
I hope I get it done this year. My project CB550 took way too long, I started in Nov 2010, and finished this May...
I'd be interested in trading my spoked wheels for mags if anyone is interested, I have new rear spokes too, the front is OK, just dirty.
Time to really get busy.
Rusty Frame
Attachment IMG_0017_2012-09-24.jpg not found
Attachment IMG_0024_2012-09-24.jpg not found
Attachment IMG_0019_2012-09-24.jpg not found
Attachment IMG_0026_2012-09-24.jpg not found
Attachment IMG_0032_2012-09-24.jpg not found
Attachment IMG_0033.jpg not found
Attachment IMG_0030_2012-09-24.jpg not found
Attachment IMG_0031_2012-09-24.jpg not found
love bikes, and anything with a engine/motor, and i love the ride way more than the destination, unless I have a passenger, then that's all that matters.
- GPz550D1
- VenturaRider
Re: KZ650 CSR from old to new
24 Sep 2012 23:57 - 24 Sep 2012 23:59
Try some Simple Green on that motor and let it soak a bit. OMR swears by it and I have had great results also.
Box stock 75 Z1900
74 Z1900
Ventura Ca.
74 Z1900
Ventura Ca.
Last edit: 24 Sep 2012 23:59 by VenturaRider.
- popssss
01 Oct 2012 23:00
I forgot about Simple Green, I'll give it a shot.
I did use Castrol purple Superclean and a powersprayer. I found drain plugs for the intake 1 inch and exhaust 1 1/8 inch and they worked great.
- popssss
01 Oct 2012 23:07
I cleaned, sanded, primed, and painted the wheels.
If I had the energy/time, and a set or front spokes, I would have re-laced both wheels.
If they start going sour later, then I'll do that otherwise I think they turned out OK.
I used 150 grain, then 400 grain, then a fine scrubbing sponge on the edge only.
Attachment IMG_0040.jpg not found
- DesertKZ
01 Oct 2012 23:36
Love those spoke wheels.
1979 KZ1000 Shaft
1979 CX500C
1975 GT750 Smoker
1979 CX500C
1975 GT750 Smoker
- popssss
04 Oct 2012 02:18
if I had the money I would have Buchannan do the spokes up with a diamond cut and copper plated, with the Rim Chrome plated.
I'm doing it all black for my brother though, he thinks I may not want to give it up when I'm done, and heck he may be right.
- popssss
06 Oct 2012 00:48
Seat info:
I found a place local that will re-do the whole seat for a decent price:
This is the overall pattern, but not exact, it's a tiered seat, but I'm doing a small tier:
This is the fabric:
This is the seat as it is: Butt ugly now
so the basic pattern won't change much bit instead of a fake stitch it will be real, and I'm taking the rear down a bit as you can see nere about an inch and a half at the rear.
The seat pan is not flat like the older ones, it rises at the rear so the passengers will have a little less padding than the rider, but passengers are supposed to be lighter anyway right?
Attachment seatpatterntype.jpg not found
This is the fabric:
Attachment CarbonFiber-100Black.gif not found
Attachment 650seatasis.JPG not found
Attachment 650seatoption1.jpg not found
Last edit: 23 Jan 2013 00:42 by martin_csr.
- popssss
10 Oct 2012 22:40
That's exactly what this bike looked like, except spoked wheels.
rear fender cover is different too, but it looks good.
I like how the clutch cover is brushed and the stator and points covers are both painted and polished.
I'm doing the same thing and boy is it taking a long time going from where I was to where it is.
- popssss
22 Oct 2012 02:29
I gotta take the tape off the cover and see what it looks like.
I forgot about the grease trick, so I painted over it all, then I'll lightly sand it off the tops of the ring, and the bars and lettering. I had to do some tricky refilling of the aluminum on one part, so it won't look as good as yours if you look close.
My frame should be done too soon, its at the powder coating. I'm thinking of painting the engine, but I don't know how it will turn out.
the first engine I painted didn't have primer, and the paint came off way too easily. I took a wire wheel to the engine and figure if I scuff it enough, then I don't need Primer, but I may just use the self etching primer, then use an aluminum paint everywhere.
I'll polish the edges of the side covers, so they'll stand out a bit, but nothing else will get the polish treatment like that except maybe the headlight.
