Yoshimura R&D Superbike
- turboguzzi
Re: Yoshimura R&D Superbike
15 Dec 2012 11:504TheKZ1000 wrote: So, I guess any street cred I had is gone....... :blush: :blush: :blush: :blush: :blush:
dont worry, we wont tell your drinking buddies, we are a discreet bunch here in kzr
- mark1122
- Keep twisting it
15 Dec 2012 14:19
r we seeing 37.5mm and 31 mm valve sizes? stock would be 36, 30. they dont usually bother increasing the exht valve size these days. they found that the exhst flows fine at 30mm.
u will want to check the valve to valve and v to p clearance before u take it all apart.
now would be the best time to put the head and cams back on and check out the cam specs. and all of these most important clearances.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
The following user(s) said Thank You: mtbspeedfreak, Street Fighter LTD
- trianglelaguna
15 Dec 2012 15:17
is it me or is the engine sitting on the floor at an angle..maybe they tilted the oil pan to help in right hand corners
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
2003 ZX12R
2007 FZ1000
- mtbspeedfreak
15 Dec 2012 17:53trianglelaguna wrote: is it me or is the engine sitting on the floor at an angle..maybe they tilted the oil pan to help in right hand corners
It's you
No oil pan included with this one
2000 ZRX 1100
1976 KZ 900- Daily Driver
- mtbspeedfreak
15 Dec 2012 19:47mark1122 wrote: r we seeing 37.5mm and 31 mm valve sizes? stock would be 36, 30. they dont usually bother increasing the exht valve size these days. they found that the exhst flows fine at 30mm.
Thanks for the advice Mark! I don't believe the motor came with a cam chain - I'd need to get one, as well as a degree wheel to set the timing, in order to check these clearances, correct?
My plans are to strip it down to the bare cases then bead blast them, the cylinders, and head before reassembling.
2000 ZRX 1100
- mark1122
- Keep twisting it
16 Dec 2012 01:11 - 16 Dec 2012 12:14
the crank has to come out to get the cam chain out. so i would think the chain is in there. could it be wrapped around the crank? looking at the pic,it looks to me like it is in there.
u only need the degree wheel to spec out the cams. u may be able to find the specs by researching the stampings on the cams. u can check all of the important measurements with plastercine or solder, and your vernier.
it looks like the intake valves hit the pistons at some time. u may want to check the valve stems for run out.
it would be wise to do the measuring now. then u can move forward with research and parts while u have it apart to clean, blast, and paint.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Last edit: 16 Dec 2012 12:14 by mark1122.
- DoubleDub
16 Dec 2012 03:29
Chains can always be split. I would be more interested in the "why", though, if it is indeed missing.
- mtbspeedfreak
16 Dec 2012 18:29DoubleDub wrote: Chains can always be split. I would be more interested in the "why", though, if it is indeed missing.
It's there. When I pulled the head, I saw a folded up cam chain in the valley. I haven't fished it out though.
2000 ZRX 1100
- mtbspeedfreak
16 Dec 2012 18:35mark1122 wrote: the crank has to come out to get the cam chain out. so i would think the chain is in there. could it be wrapped around the crank? looking at the pic,it looks to me like it is in there.
You were correct, it's down there folded up - I need to fish it out. I'll be sure to get a degree wheel soon, I'm headed back to PA for 2 weeks for Christmas so I'll catch up on this when I return.
2000 ZRX 1100
- mark1122
- Keep twisting it
16 Dec 2012 18:46mtbspeedfreak wrote:mark1122 wrote: the crank has to come out to get the cam chain out. so i would think the chain is in there. could it be wrapped around the crank? looking at the pic,it looks to me like it is in there.
Have a Very Merry Christmas Mark. Say hi to your parents for me.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- mtbspeedfreak
16 Dec 2012 19:04mark1122 wrote:mtbspeedfreak wrote:mark1122 wrote: the crank has to come out to get the cam chain out. so i would think the chain is in there. could it be wrapped around the crank? looking at the pic,it looks to me like it is in there.
I wonder if a Yoshimura Series I could be my carry-on for the trip back to CA?!?!? :side:
2000 ZRX 1100
- mark1122
- Keep twisting it
16 Dec 2012 20:54
i dought it. that pipe it almost 4 ft long. its a 1 piece pipe.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
