Yoshimura R&D Superbike
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
Re: Yoshimura R&D Superbike
14 Dec 2012 14:10
#562952
Not sure on the cams but I'm guessing pretty mild lift since the head isn't clearanced.
The Kaw List:
  • mtbspeedfreak
  • mtbspeedfreak's Avatar Topic Author
14 Dec 2012 17:22
#562969
I agree that it doesn't seem right to have the extremely heavy stator and starter on the bike - maybe it's so high compression that kicking it over would be a pain? If that were the case, I still don't know why the kicker wouldn't be removed. Though in all the vintage racing pictures of AMA Superbikes [I'm assuming this was for the AMA Superbike series, but in reality I have no idea what series it was built for], the stator, or at least the stator cover, was mounted, occasionally the bottom was shaved for more left cornering clearance.
Web Cam is right down the road from me - I wonder if I could stop by some day and have them map out the profile/duration/lift to help identify it. This motor did not come with a cam cover and I don't know if the cam cover is more limiting than the head. What is the maximum lift before having to clearance the head?
It was getting late last night so I didn't want to get elbow deep in carbon and grease, but I'm hoping to pop the head off this weekend to get a better picture at what's going on with the pistons, bore, as well as head. It's obviously only a single plug head.
2000 ZRX 1100
1976 KZ 900- Daily Driver
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
14 Dec 2012 18:00
#562977
79MKII wrote: Not sure on the cams but I'm guessing pretty mild lift since the head isn't clearanced.
My cams are .395 lift and the head needed clearance....the lobes look tall compaired to stock.
funny they went shim under?.....wouldnt have to worry about spitting shim....maybe? less chance of a minor engine failure maybe.
looks way to clean inside.....low use for sure....outside looks like chit.
  • DoubleDub
  • DoubleDub's Avatar
14 Dec 2012 19:50
#562990
The number I've seen is right around 380 or so, but each setup is slightly different.
  • trianglelaguna
  • trianglelaguna's Avatar
14 Dec 2012 21:15
#563003
34 years o so since they tuner had it as a E.L destined mill...folks may have run it on the street, dinosaur raced it as i was told, or just might have left that stuff on to be able to restart a crash/stalled bike and finish the race....
either way if the tranny is kawi close ratio factory one...that would be worth it...the reason he told me they used the early Z1 cases was that they were thinner and the motor weighed less...goes against the extra street gear....so much gets lost or re-told wrong as things change hands...I had one race team owner from back in the day stand there and tell me he had no race team in 79...which there was and the photos came later to prove my story and disprove his.....
The sum is that the metal parts dont lie or forget and what you got is a killer piece of that era....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • mark1122
  • mark1122's Avatar
  • Keep twisting it
14 Dec 2012 21:44
#563009
just put the cams in and check them out with a degree wheel.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
  • mtbspeedfreak
15 Dec 2012 00:36
#563028
Alright, I couldn't stand the anticipation, so I pulled the head off tonight.
[img
MMS_6687 by mmsmithgall , on Flickr
[img
MMS_6688 by mmsmithgall , on Flickr
[img
MMS_6717 by mmsmithgall , on Flickr
[img
MMS_6696 by mmsmithgall , on Flickr
[img
MMS_6697 by mmsmithgall , on Flickr
[img
MMS_6698 by mmsmithgall , on Flickr
[img
MMS_6703 by mmsmithgall , on Flickr
[img
MMS_6700 by mmsmithgall , on Flickr
[img
MMS_6708 by mmsmithgall , on Flickr
[img
MMS_6710 by mmsmithgall , on Flickr
[img
MMS_6713 by mmsmithgall , on Flickr
2000 ZRX 1100
  • 4TheKZ1000
15 Dec 2012 00:58 - 15 Dec 2012 01:08
#563031
Is it me or do all the pistons sit in the bores the same level.
Kz1000 I have 1 and 4 are up while 2 and 3 are down....bigtime differance????????????
Dont know about Z-engines....could be an early version crank???
Frankinfreak crank maybe???
Could be a multi-firing engine....sweet
Last edit: 15 Dec 2012 01:08 by 4TheKZ1000.
  • mtbspeedfreak
15 Dec 2012 01:58
#563041
4TheKZ1000 wrote: Is it me or do all the pistons sit in the bores the same level.
Haha sorry for leading you on... the crank is anywhere in its rotation, not TDC. I bought the motor without the cams attached, so I just popped the head off wherever the crank lay.
2000 ZRX 1100
15 Dec 2012 02:48
#563048
Good Fortune! :)
  • turboguzzi
  • turboguzzi's Avatar
15 Dec 2012 06:53 - 15 Dec 2012 06:54
#563063
:whistle:
in any flat crank four cylinder motor, pistons will be the same level when pins are at 90 degs ATDC
Last edit: 15 Dec 2012 06:54 by turboguzzi.
  • 4TheKZ1000
15 Dec 2012 09:44
#563067
So, I guess any street cred I had is gone....... :blush: :blush: :blush: :blush: :blush:
