KZ/GPZ mono shock hack was Budget Turbo Build
22 Jan 2013 16:36 - 22 Jan 2013 16:38 #568680 by turboguzzi
Replied by turboguzzi on topic KZ/GPZ mono shock hack was Budget Turbo Build
"What is measurement from floor to center of shock stud on a stock KZ?"
if you mean eyelet to eyelet its about 308-312mm
"Can the adjusters on the GPZ arm be used to straighten the wheel? Have one in slightly different rotation than another? And what is the best way to adjust these? I have seen alot of theses adjusters looking pretty beat up."
yep, its a bit triky.
to realign them, you need to release the axle nut, both clmap bolts and rotate the excenters so they are the same position compared to the grooves at the top of the clamps (aligned). after that, tighten the axle nut and just rotate both of them as one to get the right chain tension. download the manual for pics.
Last edit: 22 Jan 2013 16:38 by turboguzzi.
22 Jan 2013 18:44 #568694 by kzz1king
Replied by kzz1king on topic KZ/GPZ mono shock hack was Budget Turbo Build
I guess I am looking for ground to top eyelet just to see where my setup falls heightwise compared to stock. I should add that it is a 16 inch wheel. Thanks
Wayne
Home built KZ1000 turbo setup
22 Jan 2013 19:48 #568702 by turboguzzi
try to go by swingarm angle from this picture , quite easy to judge
www.kzrider.com/media/kunena/attachments...19ea0b04fa07a6e6.jpg
my feeling is that you are already too steep/high on the back. you will run into chain tension problems, set it lower.
22 Jan 2013 23:58 #568750 by kzz1king
turboguzzi wrote: try to go by swinga :side: rm angle from this picture , quite easy to judge
I went out to look at it and prove you wrong! You are absolutely correct. Here are some photos of the current and 2 different levels. I know you said it is easy to judge but my track record onthis project has not been good thus far. I will have to completely redo the top mount but that will help stretch the project out! Thanks for pointing this out. It could have been worse if not caught now.
Attachment DSCN2165.JPG not found
Attachment DSCN2166.JPG not found
Attachment DSCN2167.JPG not found
23 Jan 2013 15:04 #568835 by gpz1170
Replied by gpz1170 on topic KZ/GPZ mono shock hack was Budget Turbo Build
Wayne
I used the rear shock off a 1999 Bandit 1200, works great and also plentiful
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
23 Jan 2013 15:12 #568836 by kzz1king
Thanks Don, do you know what the eye to eye length is on that?
gpz1170 wrote: Wayne
don
23 Jan 2013 17:41 #568842 by turboguzzi
no problem, good on ya accepting constructive criticism, not always th ecase here in KZR ;)
bandit's length should be as the GSXR's i told you about
24 Jan 2013 12:49 #568955 by gpz1170
I believe 12"
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
The following user(s) said Thank You: kzz1king
  • wireman
24 Jan 2013 13:02 #568962 by wireman
Replied by wireman on topic KZ/GPZ mono shock hack was Budget Turbo Build
Once you get it where you think it needs to be use a ratchet tie down been rear wheel and rear loop on frame to bottem it out and see if it binds anyplace in between. B)
24 Jan 2013 15:06 #568978 by kzz1king
Great idea Wireman, thanks. I found out that the stock travel is about 4 inches on the GPZ shock and think it will be similar on any other I use so I will see what the angle looks like with that much travel. I have been trying to come up with some sort of adjustable top shock mount, maybe with 2 sets of mount locations. Have an idea.
Looking at the 3 pics are there any that look more "right" than the other?
Wayne
24 Jan 2013 16:35 #568985 by turboguzzi
24 Jan 2013 18:45 #569019 by kzz1king
turboguzzi wrote: build these and you'll be able to adjust final height later
kzrider.com/media/kunena/attachments/leg...9fcf49f29d0fcbbd.jpg
kzrider.com/media/kunena/attachments/leg...73eff48632b2b072.jpg
Those are way nice but far beyond my abilities. Really cool though. With those I would not have to redo my top mount!
Wayne
