KZ/GPZ mono shock hack was Budget Turbo Build
14 Jan 2013 15:20 #567337 by kzz1king
Replied by kzz1king on topic KZ/GPZ mono shock hack was Budget Turbo Build
wireman wrote: If you were close to Nebraska ive got a few laying in the garage depending on what style it is ;)
Thanks, I almost took the one out of the house furnace but tje ole lady wasn' keen on that idea :whistle: Local shop has one for 25, may not be same physically but has the right specs. Hoping thats all that is wrong.
Wayne
PS Where at in Nebraska. Used to live around Grand Island (wood River) in the mid 70's
Home built KZ1000 turbo setup
  • wireman
14 Jan 2013 16:09 - 14 Jan 2013 16:12 #567341 by wireman
Replied by wireman on topic KZ/GPZ mono shock hack was Budget Turbo Build
Louisville,just south of Omaha.
Ive done a lot of big commercial/institutional boiler and plumbing jobs out in the grand island/Kearney area though B)
Most of those furnace transformers are 120/208/240 primarys with 24v sec and 40va,usually its just the mounting that's a little different is all B)
Last edit: 14 Jan 2013 16:12 by wireman.
The following user(s) said Thank You: kzz1king
15 Jan 2013 00:31 #567393 by kzz1king
Well the transformer didn't do the trick although the other one was toast. This is messin with my project time!
What do you think Wireman? control valve? I have 24 volts to it, 24 to the limit control(both sides) pilot works. Not much too this thing. Its an old closet type, wall mount trailer furnace. Here is a pic of the wiring and the control unit.
Attachment DSCN2107.JPG not found
Attachment DSCN2108.JPG not found
Thanks
Wayne
  • wireman
15 Jan 2013 01:28 #567410 by wireman
Start with simple things.
Check stat,if it only has heat with no cooling just take your 2 wires (probably red and white) at the stat and twist them together till you get furnace running.
If it comes on theres your problem.
Then check the roll out switches around burner compartment/heat exchanger area,check for continuity across the switches(some of them have reset buttons).
If all else fails and you just want to jump to the end of the book you can always just jump directly from the 24v side of transformer to the gas valve for a quick second to see if the valve opens,that would be a go/no go test.
Let me know what you find out B)
15 Jan 2013 09:33 - 15 Jan 2013 13:35 #567445 by kzz1king
wireman wrote: Start with simple things.
Check stat,if it only has heat with no cooling just take your 2 wires (probably red and white) at the stat and twist them together till you get furnace running. DID THAT
Then check the roll out switches around burner compartment/heat exchanger area,check for continuity across the switches(some of them have reset buttons). WHAT ARE THESE? I HAVE@ 2 SNAP DISKS,1 HIGH LIMIT AND ONE TO KICK FAN ON . NO OTHER SWITCHES
If all else fails and you just want to jump to the end of the book you can always just jump directly from the 24v side of transformer to the gas valve for a quick second to see if the valve opens,that would be a go/no go test. I WANT TO TRY THIS. DO I TAKE ONE WIRE FROM TRANSFORMER TO THE 24 VOLT TERMINAL ON THE CONTROL UNIT AND THE OTHER TO THE THERMOSTAT TERMONAL ON THE CONTROL UNIT?
tHANKS, DIDN' MEAN TO YELL :lol: Should I here a click in the control unit? Can they be taken apart? I see in the diagram it has a vent saftey, what is that? I will add another pic, this is of the burner. If I can eleiminate a few things from being the problem it will help. Beingpilot stays lit I assume itis not thermocoupler?
Attachment DSCN2110.JPG not found
Oh yeah, it is propane
Last edit: 15 Jan 2013 13:35 by kzz1king.
15 Jan 2013 17:17 #567509 by mbosanko
Replied by mbosanko on topic KZ/GPZ mono shock hack was Budget Turbo Build
Hey from the UK :P
I'm also a heating engineer - domestic stuff. Yep, you,re right, if pilot stays lit the thermocouple is ok. (The thermocouple allows the gas valve to stay open by a solenoid action) 'Cos it only stays on a pilot flame, the valves that allow more gas to the burner, and therefore full flame, aren't opening. Could be a dodgy 'stat or dodgy gas valve (stat more common fail) hope this helps ya a bit - good luck B)
Cheers
Bos
15 Jan 2013 18:36 #567520 by kzz1king
Thanks. I started out knowing very little and now I know just enough to be dangerous! Hopefully sort it out tonight so we can get back to our regularly scheduled program.
Wayne
  • wireman
15 Jan 2013 19:54 #567541 by wireman
Vent safety switch looks like a roll out switch to me ,should be somewhere in circuit around burner compartment incase of flame roll out or high temp B)
  • wireman
15 Jan 2013 20:01 #567545 by wireman
Attachment detail_535_MOD-5H75002-2.jpg not found
Attachment imagesCAS7QT4X.jpg not found
15 Jan 2013 23:39 #567592 by les holt
Replied by les holt on topic KZ/GPZ mono shock hack was Budget Turbo Build
FYI, my furnace is now working thanks to you Wireman! I was ready to kill my installer. 3 years of this and has done nothing but gotten worse. Mommy happy, I'm happy.
P.S.
I'm a tightass! I wouldn't hire someone to fix it!
Les
  • wireman
15 Jan 2013 23:54 #567594 by wireman
Well yours was an easy over the phone fix! :laugh:
From the psychic boiler/furnace over the phone repair friends network.com :woohoo:
16 Jan 2013 01:10 #567611 by kzz1king
Kind of tight myself Les! after testing every circuit I jumped right to the control valve and could hear it working. Finally found a wirenut that wasn't making contact with both wires. I must have did it when I replaced the faulty transformer. Thanks for the help guys.
Wayne
